4 X 8 pieces of plywood only design
Postby Gerald_G » Fri Jun 02, 2006 1:11 pm
Has anyone come up with a design that can use a single sheet of 4 X 8 plywood for the floor, and also the same for the walls ?
I have pasted in a sketch of something I was thinking would work OK.
Walls and floors could be made of a single sheet each.
I like the hatch design on weekender for simple construction, straight pieces only for the hatch, with simple supports needed for the angle position.
Just posting this here for comments etc...
Gerald_G
Images: 85
4 X 8
Postby philr » Fri Jun 02, 2006 2:26 pm
I just came out of hiding and posted some Sketchup drawings I did for a quick simple one person tear in my album. Nothing over 4 X 8 but the trailer. GREAT Forum here by the way.
Phil R
philr
Postby madjack » Fri Jun 02, 2006 3:05 pm
Gerald...most all of the original TD designs were 4x8 to take advantage of standard sized sheet goods...in the interest of roominess these designs have been streched to 5 wide and 10 long...most of these later designs can be shrunk down to 4x8...our Alligator Tear is 4x8....
Postby hammer & tongs » Sat Jun 03, 2006 10:14 pm
...My TD is of the 4X8 design ...floor and both walls..see my album..
Two sleep comfortably..albeit cozily..uses regular foam mattress designed for a 3/4 bed. ..48" X 72".. so we squeeze a bit on either side..
There must be many more..I believe the Cubby plans are like that..
hammer & tongs
Last edited by hammer & tongs on Sat Jun 03, 2006 10:40 pm, edited 1 time in total.
" By whose stripes you were healed ."
(1 Peter 2:24b )
hammer & tongs
Images: 9
Postby Dean Williams » Sat Jun 03, 2006 10:28 pm
Mine is also a 4x8 design. Just room for one, but that's all I need. You can see what I have so far in my album.
Dean (no, not that Dean. The other Dean.)
...Hooked. Hooked bad.
Dean Williams
Images: 36
Postby jje507 » Sun Jun 04, 2006 7:38 am
Mine is also Based on 4 x 8.
Plenty of room if you think ahead and plan right.
(I didn't and had to change a couple of things)
Check out my album for finished pics. :)
jje507
Images: 16
Postby toypusher » Sun Jun 04, 2006 7:49 am
Gerald,
The Cubby from Kuffel Creek is a 4x8. Look at my 'www' to see mine. The frame is a HF 4x8 (shortened a couple of inches) and the floor is a single 4x8 sheet of plywood and each side is from a single 4x8 sheet!
Check it out here for plans: Cubby
toypusher
Images: 324
Return to Member Designs
