jstrubberg wrote:Yikes! Unless you are carrying a large load, 50 or even 40 psi is a LOT of pressure!
Be aware that the rating on the side of the tire is the MAX pressure for the tire, not eh pressure you should be running it at under less than maximum load.
Has nothing to do with compressors, I'm just startled that folks run that high a psi. You won't get maximum life out of a tire at those kinds of pressures.
Hope this isn't too much of a derail.
jeff0520 wrote:If I woke up in your shoes, what I'd do is take my small compressor from home along. You can run it off an inverter, Just look at what the amp rating on the compressor is, and use Ohm's Law to convert to watts. For example if it's a 10 amp compressor, 10 amps times 120 volts gives you 1200 watts. I'd pick up a 1500 watt inverter and put my little pancake compressor in the trunk and run it off the inverter. No more worries about the puny little portable ones
bdosborn wrote:jstrubberg wrote:Yikes! Unless you are carrying a large load, 50 or even 40 psi is a LOT of pressure!
Be careful what you recommend, not everyone has a teardrop this forum. Those of use with fuller figure trailers run higher pressures (or this can happen).
Users browsing this forum: Bing [Bot] and 6 guests
