OK! Do you recall????
Postby southpennrailroad » Sun Jul 16, 2006 11:25 pm
I was out joy riding to Bedford, Pa and on the way home I took the Lincoln Highway and had to do a doubletake. I just had to take this. :thinking: :shock: :? :x :drofl: :wacky :thumbs down: $> :snappy: :disappointed: :crying2: :shocked:
Long time researching the abandoned South Pennsylvania Railroad along the Pennsylvania Turnpike. God will guide me. As he has done so in the past. southpennrailroad.com
southpennrailroad
Postby asianflava » Mon Jul 17, 2006 2:00 am
I guess they don't have enough room to put the "2" in front.
asianflava
Postby Ira » Mon Jul 17, 2006 7:43 am
Is anyone else having a problem seeing that at all? Mine is really dark and I can't read a thing on it.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby madjack » Mon Jul 17, 2006 1:22 pm
...same here Ira...pic is too large and too dark............................................ 8)
Postby Chris C » Mon Jul 17, 2006 1:34 pm
Ditto. :?
Chris :D
Chris C
Postby southpennrailroad » Mon Jul 17, 2006 2:30 pm
Thats weird, I resized it to 50% and compressed it as well. I have to work more on this picture stuff.
southpennrailroad
Postby thobbs » Mon Jul 17, 2006 2:35 pm
I wish fuel was under a dollar again. Last year we spent $32,000 on fuel and this year we have already spent over $18,000. It's killing us. :cry: :cry: :cry:
thobbs
Images: 21
Postby asianflava » Mon Jul 17, 2006 2:35 pm
For me, it is usually easier to resize it by pixel count, 640X480. Then I compress it by file size ~50K
asianflava
Postby Ira » Mon Jul 17, 2006 2:38 pm
Depending on the program you're using, when you resize it, you have to have "Resample Image" checked. (If you have that as an option. AGain, it depends on your program.)
Otherwise, it will make the file's "dimensions" smaller, but it will increase the "resolution" at the same time, when it shouldn't.
This makes the image "functionally" larger for web use, because the web can't make these distinctions and the correct adjustments for you.
Web images have to be 72dpi. So a 4" wide image for the web at 72dpi is about 4" wide. The same 4" wide image at 300dpi will be 16" wide when someone sees it!!!
Yours was 19" wide! Here it is resized to 8", and I tried to lighten it for legibility.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby roadtrippin » Mon Jul 17, 2006 3:33 pm
a 2? Here it would need a 3. *(#$&%*@)@ greedy #&*@)_!*#&%$&*(%#
roadtrippin
Images: 15
Postby southpennrailroad » Mon Jul 17, 2006 4:16 pm
Ira wrote:Depending on the program you're using, when you resize it, you have to have "Resample Image" checked. (If you have that as an option. AGain, it depends on your program.)
Thanks IRA This station has been closed for some time but was a fun shot to photograph. :applause:
southpennrailroad
Postby BrwBier » Mon Jul 17, 2006 8:46 pm
I was confused on resizing pictures untill I found a place in my camara program to email the pictures. I just email them to myself and when it does, it asks if I want them resized for easyer mailing and reciving. I just answer yes and it is all taken care of for me. Then I open attachments in email and save as.
Brwbier
BrwBier
Images: 100
Postby curiouswill » Mon Jul 17, 2006 9:44 pm
yeah I really hate the gas prices like that. what a messed up government. Do you know that we have a pretty good chance of having many of the cars converted to ethanol gas use(or something, i'm not sure of the name) which are made from wheats and similar stuffs such as corn. The only barrier really is the tariff. the government have set a 100% tariff on such a product from oversea and 0% on gas.
I saw a show talking about the energy crisis on the discovery channel and I only remember 1 part of that show which is what I've just explained above.
curiouswill
Postby Ira » Tue Jul 18, 2006 7:29 am
asianflava wrote:For me, it is usually easier to resize it by pixel count, 640X480. Then I compress it by file size ~50K
Yep...but a lot of people don't realize that 72dpi is about an inch, so they can't make the calculation in their head that 640X480 is about 9" by 6 1/2".
Here we go again!
Ira
Forum Storyteller
Images: 118
