Swamp coolers add moisture for the desert dwellers; A/C removes moisture
for the humid areas. If you use one for the other then you can have a real mess on your hands...
I will take some A/C here in Florida...thank you very much.
Rod
doug hodder wrote:I always forget about that Ira...out here, it's so dry in the summer that even the lizards pack a Chapstick. With humidity, it'd be like having a cold vaporizer running...nice clammy damp sheets in a tear!!! Doug
rowerwet wrote:http://www.instructables.com/id/Homemade-air-conditioner/
an idea like this could work for a TD, substitute a car heater core and a couple computer fans, you will be removing tons of condensation from the air so make sure there is a good drain under the heater core ( I tried this idea in my car, going into my TD soon, it looked like it had a leak there was so much condensation) the ice stays in the cooler and should last for hours . put a switch on the pump or even fancier, a thermostat, to regulate the temp. and run the fans on another.
teardrop_focus wrote:What the hell is rowerwet's avatar a picture of?
Shadow Catcher wrote:Near as I have been able to discover there is no short cut to AC (other than swamp cooler) for a teardrop. The closest thing is a truck cab AC unit that is diesel powered (motor). I think you could power an automotive AC compressor with a small motor which would be an interesting exercise, or just use a small generator. We were very happy to have our modified window shaker at CAG, it worked beautifully.
