During some brainless sort of work the other day, my mind wandered to teardrops--imagine that. I got to thinking about the actual value of insulation in a teardrop. Seems to me that, apart from those in the far North and those that pursue winter camping in harsh climates, insulation has little value as insulation.
Most home-builts seem to have either very good ventilation or AC. Those with ventilation are going to cool off very fast because of the small volume of a tear. Most of the AC builders use small residential units that still are way bigger than actually needed for a tear.
So it seems to me that the biggest utility of the insulation is in creating a matrix that increases the strength of light-weight construction, i.e., a filler. If I'm not off base about that then it makes sense to use the cheapest, lightest material for the middle of the sandwich. Thus, it would make more sense to use, for instance, bead-board as oposed to blueboard.
Any thoughts, comments, or suggestions for even cheaper material welcome.
