Computer power supply question
Postby Nitetimes » Fri Nov 14, 2008 12:52 pm
Here is what I am considering for inclusion in my next TD build.
I am going to incorporate a full desktop PC without the desktop part into a small hidden compartment in the cabinetry. My reasoning is.... ( I know some will say why not just use a laptop) .... I can build a much better PC for the money than I can buy a good laptop for sooooo (and it can be dedicated to just what I want in the TD) What I am trying to come up with is a solution to one problem.....I need to know how I can eliminate the need for the 110v part of the power supply. I know that PC's run on 12vs and under so I want to eliminate the necessity for 110v all together, LCD monitors are 12v and under too. There should be a way to hack a power supply so it will work directly off of a 12v battery, any ideas????? :thinking: :thinking: :thinking:
I haven't tried it yet so I'm not sure which direction to go.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Wimperdink » Fri Nov 14, 2008 1:15 pm
I have limited knowledge of pc power supplies, but there are functions to it that the power supply must recognize a power good signal from the main processor before it fires up the rest of the pc. Also a pc requires a good clean 12v, 5.5v, and 3.?v signal. You may burn it up if the voltage fluxuates. Just my limited 2 cents.
There is always the inefficient way of battery to inverter to powersupply but I completely understand the reasons you want to eliminate that.
edit - I believe this site may have what you need. Otherwise google carputer. http://www.powerstream.com/mini-itx.htm
Wimperdink
Images: 33
Postby Nitetimes » Fri Nov 14, 2008 1:41 pm
This seems to be what I have in mind but it appears everything they have is "out of stock for the foreseable future"???
What's up with that?? :thinking:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby rainjer » Fri Nov 14, 2008 3:38 pm
You may want to consider a inverter instead. Go 12v to 110 & let the power supply distribute the correct voltage.
Jeremy
rainjer
King Koleman
Images: 11
Postby Bill_Storey » Fri Nov 14, 2008 4:39 pm
You might look into power supplies for car computers such as these.
Sorry. I just re-read the WHOLE post and saw someone beat me to it.
Bill_Storey
Postby Juneaudave » Fri Nov 14, 2008 5:02 pm
You can also get a 12v ATX power supply such as this...12 ATX iffn a guy wanted to mod and existing desktop or case... I got no idea how well they work
Juneaudave
Images: 380
Postby Nitetimes » Fri Nov 14, 2008 5:37 pm
Juneaudave wrote:You can also get a 12v ATX power supply such as this...12 ATX iffn a guy wanted to mod and existing desktop or case... I got no idea how well they work
Still gotta have 110v with that. I'm trying to get away from the 110 all together and just supply the 12v the PC needs. Maybe I'm thinking about it the wrong way. Got to look into it more.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Miriam C. » Fri Nov 14, 2008 6:26 pm
:thinking: Maybe if you go to a "used" puter store you can get the batteries for a lap top. Then use a car charger to meet your maintenance needs. :thinking: Now if this won't work it is cause I dunnnnooooo. :D
Postby Elumia » Fri Nov 14, 2008 8:08 pm
buy a used laptop with a broken screen. Should get it cheap. can build it in where you want. it will likely require 5V DC. you can get a dc/dc converter that takes 12v to 5v. it will have its own battery that you can charge from the main power.
Another neat ides, get a USB hub and put some LED lights that are powered of the USB ports 5v
Mark
Elumia
Images: 15
Postby Jiminsav » Fri Nov 14, 2008 9:01 pm
they make a 12v to 12v power supply for cars, it's a little pricey tho.looky here
Jim in Savannah
Jiminsav
Images: 40
Postby BrwBier » Fri Nov 14, 2008 9:54 pm
I don't know about a laptop using 5v, mine is a 19v. A 12v power supply is about $150.
BrwBier
Images: 100
Postby Elumia » Sat Nov 15, 2008 12:13 am
got the voltage wrong, but this is what I was thinking of:
http://www.powerstream.com/ADC-ABS.htm
Elumia
Images: 15
Postby Nitetimes » Sat Nov 15, 2008 12:15 am
Jiminsav wrote:they make a 12v to 12v power supply for cars, it's a little pricey tho.looky here
Hadn't found that one...80 bucks ain't that bad. :thumbsup:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Greg M » Sat Nov 15, 2008 1:42 am
Hey Nitetimes,
Take a look at some of the mini ITX pc's out there. Most run off a 12 volt power supply, and they come in a really small form factor.
I've built one for my trailer, and when it's not in use it sits behind my TV at home as a media machine. It's the heart of the 5.1 surround mobile theater setup that I'm building into The Locust.
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Postby rhltechie » Sat Nov 15, 2008 7:02 am
Rich,
funny you should bring this up...I was just thinking about this the other day. now I have all the answers I was looking for...thanks for askin'! :D
rhltechie
Images: 49
