Old Mill
Old Mill
Postby dhazard » Thu Apr 06, 2006 11:18 pm
I told my new boss about breaking my drill when I was mounting the coupler to my frame, :( he took me to a back room at the TV station and asked if I could get rid of this. :shock:
The nametag is missing, anyone have any ideas as to the make and what type of collets it uses I think it might be an R-8. I will try and get a pic of the chuck and measure the size it looks like it is about 1” diameter. The motor looks like it is a replacement, it is a 1 ½ hp 220v with a speed controller. Pretty good find.
8)
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby Kevin A » Thu Apr 06, 2006 11:22 pm
Looks like an old piece of junk to me, I think you need to ship it over here to Eureka :roll: :thinking: :lol:
We have one very similar to that at work that we use in the balance room to remove material from pistons during the balancing process. I'll see what I can find out about it.
Kevin A
The other guy
Images: 289
Postby dhazard » Thu Apr 06, 2006 11:30 pm
I just about killed two of my friends moving it into my garage. I think I will keep it, or the friends that helped might just kill me… :BE
dhazard
Images: 122
Postby Kevin A » Fri Apr 07, 2006 12:09 am
A google search for Mill/Drill turned up this one, It sure looks a lot like your's. It appears that it uses R8 collets too. Mill/Drill
Kevin A
The other guy
Images: 289
Re: Old Mill
Postby Gage » Fri Apr 07, 2006 12:26 am
DHAZARD wrote:Image
The table looks different Kevin, and other things about it. That mill looks like one of about 6 that Northrop sold off (real cheap) around '91. Once you figure out the slop, it's a fun little mill that will get the average home job done. Good find.
Have a good day.
:thinking:
Image Image Image
Gage
Images: 28
Re: Old Mill
Postby Kevin A » Fri Apr 07, 2006 12:34 am
Gage wrote: The table looks different Kevin, and other things about it. That mill looks like one of about 6 that Northrop sold off (real cheap) around '91. Once you figure out the slop, it's a fun little mill that will get the average home job done. Good find.
Have a good day.
:thinking:
Gage,
I agree there are obvious differences between the two mills, but I would imagine most of these imported mills use the R8 collets.
Kevin A
The other guy
Images: 289
Postby Gage » Fri Apr 07, 2006 1:27 am
That mill looks like a late 40's or early 50's.
Have a good day.
:thinking: :thinking:
Image Image Image
Gage
Images: 28
Postby doug hodder » Fri Apr 07, 2006 1:38 am
Sorry Dan...I mis read a word in your post...when he asked if you could get rid of this, I thought he meant the Harley in the background!!..... :lol: :lol: :lol: as per my PM...I'm still betting it's a Central....doug
Postby dhazard » Fri Apr 07, 2006 10:47 am
I don’t think the mill is an import. It was at the station when my boss started 30 years ago.
This is the only label / markings on it
Collet size
Other side
Thanks for the help Dan
dhazard
Images: 122
Postby Kevin A » Fri Apr 07, 2006 11:11 pm
Gage wrote:That mill looks like a late 40's or early 50's.
Have a good day.
Ya know, Gage,
You're probably right. I wasn't around back then so I guess I'll have to rely on the memory of you old farts. ;) 8) :lol:
Seriously though, I'm so used to seeing the imported clones of that machine, I guess I didn't recognize the real McCoy.... :thinking: :?
Kevin A
The other guy
Images: 289
Postby Gage » Fri Apr 07, 2006 11:56 pm
That chart if I remember correctly is your speed settings for the head depending on where you put the belt. And I'll almost bet you that mill was a much lighter green . I can't believe there isn't a name embossed in the main body on the side. Boy, have you got me thinking about this thing. I printed up a picture and going to take it down the street to a guy whos been a machinest for over 50 years, he should know. I keep thinking one brand but I'm not going to let it loose yet.
Have a good day.
:thinking:
I've only worked in a machine shop for a short period of time but because of my job (when I worked for a living), I've spent a lot of time in the shop.
Image Image Image
Gage
Images: 28
Postby dhazard » Sat Apr 08, 2006 12:37 am
Thanks Gage, yes the chart is the speed settings for the belts.
I don’t think that it was ever repainted.
In a past life in a far away land I ran a Blanchard grinder, it had a 3’ grinding wheel with a 5’ table… That would definitely classify as a dirty job. I ground the aluminum top plates for professional video recorders. It used a magnetic table to hold the aluminum parts… fun stuff sure don’t miss it.
Can you show him the pic of the chuck and ask if that is for an R-8 collet setup. I would like to get some end mills for it but it didn’t have any holders for them. I have tried to find a drawing online but no luck.
Thank Dan
dhazard
Images: 122
Postby Chris C » Sat Apr 08, 2006 12:40 am
Dan,
I've run a surface grinder for more hours than I'd like to admit. It also had a magnetic table. Could you please explain to me how you held aluminum down using a magnetic table? :thinking:
Chris :D
Chris C
Postby dhazard » Sat Apr 08, 2006 12:50 am
I was wondering how long it would take for someone to pick up on that. :thumbsup: What we did was put steel bocks under the locating bosses under the part, then put Steel blocks around the edges to hold it in place without distorting the aluminum casting. 8)
dhazard
Images: 122
Postby Chris C » Sat Apr 08, 2006 1:45 am
Thank ya kindly, sir! :thumbsup:
Chris :D
Chris C
