by Lesbest » Thu Aug 23, 2007 6:12 pm
First BEFORE ANY answer can be attempted, we need to know, make, model, year, and engine. Egr codes and their respective repairs are NOT universal.
If the car is a Ford with a V8 of the 95 to 96 era it could be a bad tube that runs from the valve to the exhaust pipe, if it is of the 99 to 02 era it could be carbon build-up under the trottle boby on the intake manifold.
If it is a GM car with the electronic valve with 3 solinoids it could be carbon in one of the orifices, or the passage to the valve could be coked up and 27 new valves won't fix it--you need to do a router rooter job to the clogged passage. If it is a Vortex V6 in a truck the valve rarly gets clogged, but has carbon get stuck under the seat and cause the valve to stay open slightly, and maybe cause a high idle or a stalling at idle condition.
All of the manufacturerss have trouble charts for trouble diagnosis of all codes and you have to follow each test and answer yes or no. No maybe. Once you enter a chart you are going to replace something. When that doesn't fix it you use the computer to help diagnose the problem-usually the old part is not faulty then, if the results were the same. The computer can't "see" what it expected to see and tattles on itself. A code for a coolant sensor could mean that the wire is broken somewhere, the sensor is faulty, it is unplugged, the computer is bad on that circuit, or nothing is wrong, the computer is confused. It does not tell you the sensor is lying to the computer--sensors says it's 100, when it is a cold engine at 35.
The logic to fix cars with computer controls can't be confused with throwing parts at it. The spark plugs with no electodes is not something the computer can see or looks for. If the ignition coil can fire the fuel mixture the computer doesn't care.
OBD I On board diagnostics used from 1981 to 1996 uses different logic to repair than OBD II which is 96 to current. To turn off the light in OBD I you unhook the battery, OBD II have to use a code reader, unhooking the battery will not turn off the light, but you will have to reset the radio and the clock.
You can thank all the legislators for their help in causing this to occur, but one of the pluses is that we now can get 35mpg with some cars that previously would not gat anywhere near that, all with 200hp. too.
Hope this helps, but we need to know what we are working on?
Les
Music is like chocolate.......you can't really enjoy it unless the rappers are gone.
