Joshua wrote:The only two that concern me from a medical stand point is the bleach and "something to cut with".
Actually, Joshua, bleach is a pretty good disinfectant for tools and surfaces, when disinfecting is needed. It's way more effective than alcohol--which kills only that which it drowns.
'Something to cut with' doesn't necessarily translate to sucking poison out of a snake bite. It can be something to cut clothing off or away from a wound or injury--or to cut larger bandages or tape to a more appropriate size. For that, you need a good pair of what we used to call EMT scissors (the kind that were advertised cutting a coin--serious kitchen/poultry shears will work in a pinch). They're designed to cut materials--not skin--and they look like this:
http://www.firstrespondersupplies.com/pm87.htmIt's always good to have a wrapped razor blade on hand--not to cut skin, but to give a good sharp cut to things when those bandage scissors I just described would be too bulky to carry. So I don't carry EMT scissors in my hiking kit, which fits in a travel soapbox or small ziploc bag. But I do carry a wrapped razor blade and a sharp pocket knife, all the time--even in the small kit (and the EMT scissors are in my vehicle kit which lives in the truck, parked back at the trailhead.) It is appropriate to carry the size/type kit you need for the situation...one kit doesn't work for everything.
One thing to remember for everyone who keeps a kit IN the vehicle or trailer all the time--a lot of first aid supplies are affected (in a bad way) by extremes of temperature. Adhesives on bandages melt, tubes of ointment ooze or freeze/thaw and then burst, ice packs burst and things like Betadine just plain lose their effectiveness. So if you live where the vehicle temp gets over 80 degrees or goes below freezing for extended periods of time, check your kit and toss the stuff that's suffered the temp extremes.
I also have the training to 'cut' -- but I wouldn't do anything even approaching surgery on animal or human in the wilderness unless I made damn sure I had everything I needed to stop bleeding, suture, clean up and dress the wound, etc. That's stuff for a field medic pack or a field hospital--way more than even I carry in a first aid kit, and I carry a lot of stuff.
The biggest dangers in responding to an emergency come from not making sure that you (the responder) is safe--and from the responder trying to do more in a tough situation than his/her equipment, training and/or skills can handle.
If nothing else, spend a day out of your life to take CPR/ AED and first aid from the red cross. You never know when you have to use it, hopefully never.
Totally agree. And if there are no Red Cross classes in your area, check out the American Heart Association, who also offer CPR/AED classes, or your local hospitals for their outreach first aid/CPR classes.
Gaelen
NYS/DOT AEMT III #08499 (inactive)
