Creamcracker wrote:In October I drove a brand new Chrysler 300 to Minnesota from Virginia. It had 135 miles on it when I left. It was of course at highway speeds. When I get to driving around St. Paul the car starts to stall, check engine light on, and do other weird things. I took it to the dealer there and they said the Computer had lost it's program so they re-programmed it. Next day the car still stalls -- back to the dealership....they tell me that I must have put E85 in the car and they would need to put additives in etc, etc and charge me $150 since that was not covered by warranty.....now I'm a pretty car savvy guy and there was no way that I would pump gas from a clearly marked different color almost neon lights pump marked E85...Anyway they tell me it's there and so I have to assume that the gas station must have put the wrong fuel in their tank.....however my son filled up at the same pump and was having no trouble. The dealer told me the car was probably going to stall out a couple more times until the E85 had cleared the system...it did stall out ......all the way back to Virginia and after a week at the dealership in Virginia.....and consultations with the manufacturer the problem was diagnosed as a "Crank shaft sensor" which was then replaced....computer reprogrammed and now ......what a difference.....SO it was nothing to do with E85 just some BS from a dealership that wanted to make some money. Just needed to vent that.....I want to write to that dealer and ask for my $150 back but my wife says not to...not worth the hassle ......just let it go! .........?
Philip
Miriam C. wrote:Creamcracker wrote:In October I drove a brand new Chrysler 300 to Minnesota from Virginia. It had 135 miles on it when I left. It was of course at highway speeds. When I get to driving around St. Paul the car starts to stall, check engine light on, and do other weird things. I took it to the dealer there and they said the Computer had lost it's program so they re-programmed it. Next day the car still stalls -- back to the dealership....they tell me that I must have put E85 in the car and they would need to put additives in etc, etc and charge me $150 since that was not covered by warranty.....now I'm a pretty car savvy guy and there was no way that I would pump gas from a clearly marked different color almost neon lights pump marked E85...Anyway they tell me it's there and so I have to assume that the gas station must have put the wrong fuel in their tank.....however my son filled up at the same pump and was having no trouble. The dealer told me the car was probably going to stall out a couple more times until the E85 had cleared the system...it did stall out ......all the way back to Virginia and after a week at the dealership in Virginia.....and consultations with the manufacturer the problem was diagnosed as a "Crank shaft sensor" which was then replaced....computer reprogrammed and now ......what a difference.....SO it was nothing to do with E85 just some BS from a dealership that wanted to make some money. Just needed to vent that.....I want to write to that dealer and ask for my $150 back but my wife says not to...not worth the hassle ......just let it go! .........?
Philip
Loosely quoted "the only thing needed for crooks to thrive is for knowing people to do nothing."
You really should make a formal complaint to who ever regulates auto repair in your state. Then you need to take all measures to get your money back and include gas for the running back and forth. JMO.
Elumia wrote:Probably the reason you got screwed by the dealer is that likley many others "let it go" too, so they now have a license to steal. Dealer service has added to the illusion that American cars suck. You should also write to the Mfg. In these tough times, many dealers will be closed. The Mfg has an interest in keeping the good ones open.
If they don't resolve your problem, I would contact small claims court. Sticking to your principals may save some else down the line.
Mark
