Sounds like I can move forward now
The only other issue to solve is chrome or black...so many decisions
Rob
48Rob wrote:Thanks for the advice on the capacitors.
I have capacitors on the door speakers in my truck, had to install them after putting big speakers behind the seat.
The door speakers kept trying to kick out bass to keep up with the rear speakers, and sounded horrible.
Now they only produce mid range and higher sound.
This is the same concept you're trying to show me for the 4" speakers, right?
Trackstriper wrote:My only concern with adding the capacitors is that you might clip out a lot of musical information, including voice. If we assume a 4 ohm speaker impedance, a 100uf capacitor will drop your electrical output power to the speaker by 50% at 400Hz (3db down at this "crossover" point). One octave lower (6db farther down)...200Hz... you have would have 1/4 of that 50% power or about 12% of what you have at say 800-1000Hz. For reference, middle "C" on the piano is about 260Hz. You might set a lower crossover point, maybe 200Hz so as no to lose music. See Rocky's charts. This would take a 200uf capacitor (or two 100's wired parallel...they add this way). I'm not knocking Rocky's previous information because it can save some amplifier power from being wasted, but it just sounds like the frequency is too high unless you have some additional low frequency speakers, which you don't.
asianflava wrote: If you think you need more bottom end, you can remove the cap or try a different size.
