Bungee cord storage ideas
Postby godskid » Fri Oct 08, 2010 11:54 am
EffieRover wrote:We have a scrap of plywood in a trapezoid shape (imagine a triangle with the top point cut off). Both long sides have notches all the way down. Different sized bungees get wrapped around different parts of the wood and hooked in the notch according to where they fit. Hole drilled in the top for a handle (which I use to hang it from the floor joists in the cellar half the time). Can't be a foot-and-a-half tall and about a foot wide ... works nice.
THAT sounds like a great idea!
godskid
Images: 10
Postby sagebrush » Fri Oct 08, 2010 9:50 pm
oklahomajewel wrote:I haven't done it , but remember seeing that you could take a scrap peice of pvc pipe, at least 3" wide and hook the cord on one end of the pipe, stretch to hook the other to the other end. The cords will then be taut and not tangle. Really long ones can hook on the end and go thru the inside of the pipe to the bottom then wrap and back up.
I would guess you would cut the pipe to at least a 12" length... don't know.
Julie
Yep, used 4" thinwall PVC vent pipe. Just long enough to get a little stretch. You can get a mess of bungees on it. Will
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
