by eamarquardt » Fri Mar 11, 2011 5:45 am
Having lived through several BIG earthquakes here (Northridge 1994 and Sylmar 1971) I've noted that the damage is somewhat localized. As few as ten miles away from areas with devistating damage, things are quite normal and you can get just about anything you need. If worse comes to worse, you can just get the heck "outta Dodge". You may need to take a circuitous route but I'm reasonably confident there will always be a road out of the area open (or soon will be).
I think the risk of Tsunamis is the risk that is underrated!!! Japan, as we speak, is finding this to be so and I think before the day is over that other areas will also find themselves in trouble. They do a much more through job of wiping the slate clean than an earthquake alone does.
If a big one hits, get on the telephone immediately (even before the ground stops shaking) and call someone out of the area to let them know you are ok. They can then call your friends and family (prearranged lists) and let them know you're ok. The phone networks will soon be overloaded and be shut down. In the moments following a quake, though, they will still be working. This is based on my experience after two big ones and working in the phone company's "Emergency Operating Center".
Gus
