need opinions on a car problem
Postby PKCSPT » Fri Jul 15, 2011 9:40 pm
Crank shaft sensor,, no it neer threw a code,,, not once.
Seems to be working now,, thank you eeryone for your thoughts. I knew this was a good place to ask.
121172 116946 159644
PKCSPT
Images: 61
Postby Alfred » Fri Jul 15, 2011 10:32 pm
I'm not an expert on cars, but I once had an intermittently clogged fuel filter that caused the car to stall sometimes. Changing the filter was the fix in my situation. Hope you get the problem id'd and fixed. Good luck! AL
Alfred
Images: 368
