Dan
PS do you have a name that we can call you
funomenal wrote:Hello Knowledgable Fellows:
As I stated in my previous post, I purchased 20 inch heavy duty bicycle tires for my cyclekart due to the rare market for 17 inch Honda wheels. I plan to simply weld the 3/4 inch hub of the wheel onto a 1 inch "live" axle. The azuza axle is one inch but tapers down to 3/4 inches . However this 3/4 inch area is only 2 inches but the wheel hub is 3 1/2 inches in length.
I need to find a crude method to shave off 1/4 inch of the axle to get it to fit the 3/4 inch hub. Any suggestions since I don't own a lathe?
I thought I could use a bench grinder and a lot of time and elbow grease. Any ideas?
funomenal wrote:I must be overthinking because I can't figure this out (drivetrain).
I want to use a "live axle"(axle and wheel move/welded together) and also incorporate the Comet tav-30 clutch. So I have the following:
6.5 horsepower engine with 3/4 inch shaft. I assume I connect the Comet Tav 30 clutch to the engine. So how do I connect it to my main sprocket (72 tooth) that is connected to my main axle? Help!
I have a question. What do you do with something like this after you've built it?
--rick
