toypusher wrote:Fenlason wrote:toypusher wrote:Fenlason wrote:I will use the tamper on my bench cut section.. and use my leaf blower on the same. I am anxious to get out on my other trails.. but it is wet out there.. or wet to bring my equipment. There is more cutting I could do in the new playground area. Perhaps service my Toro today..
I meant to ask when you mentioned the bench cutting before, but forgot. How much did you have to cut in on the high side of the trail??
hmm maybe 6" or so.. we will see how that works. I think it will be level enough [still want a slight outslope] It just might not be wide enough...
A couple hundred feet sounds like a bit of work then.
Fenlason wrote:toypusher wrote:Fenlason wrote:toypusher wrote:Fenlason wrote:I will use the tamper on my bench cut section.. and use my leaf blower on the same. I am anxious to get out on my other trails.. but it is wet out there.. or wet to bring my equipment. There is more cutting I could do in the new playground area. Perhaps service my Toro today..
a little bit.. although it is wet and soft right now. I could use a bigger tool...
toypusher wrote:Guess that I should be heading out the door soon. Have some stops to make and the traffic between here and the Doctor's office is typically pretty bad this time of day.
Have a good one!
toypusher wrote:Fenlason wrote:toypusher wrote:Fenlason wrote:toypusher wrote:Fenlason wrote:I will use the tamper on my bench cut section.. and use my leaf blower on the same. I am anxious to get out on my other trails.. but it is wet out there.. or wet to bring my equipment. There is more cutting I could do in the new playground area. Perhaps service my Toro today..
At least the one you have is not small and pink is it??
Fenlason wrote:Lisa.. I found it.. the whole show in 3 parts on youtube..
http://www.youtube.com/watch?v=3dbkUpRR ... re=related
http://www.youtube.com/watch?v=QPTGSZF_ ... re=related
http://www.youtube.com/watch?v=e-bMi9oK ... re=related
this has something to do with our skates...
toypusher wrote:Glenn, I just tried to check you last post on the 'Killer' thread and it says 'No posts exist for this topic' or whatever like our thread was doing!!
If you go back a page, it is fine - just like our campfire thread!
Fenlason wrote:toypusher wrote:Fenlason wrote:toypusher wrote:Glenn, I just tried to check you last post on the 'Killer' thread and it says 'No posts exist for this topic' or whatever like our thread was doing!!
towards the end of the page.. it does that.. then goes back to "normal"
Weird stuff!
Time for Mike to upgrade the board, me thinks.
upgrade...you mean replace us with better looking, smarter people...
Fenlason wrote:last nights ride.. I felt rusty on some of my skills... although one of the sections was pretty rough also... I have more trail work to do.. but also It is pretty normal each season to need a little time.
