Twenty min walk and Total Gym tonight, back at level 2 (2X25 reps)
Jeanne no exercise.
The Total Gym may not be as great as I thought. It works by having you work against a percentage of your own weight, cut in half on exercises where the pulley handles are used, and there lies the part I didn't take into consideration, the fact that the heavier you are, the bigger the jumps in resistance.
for example, at level two resistance, at a body-weight of roughly 260, I'm working with 15% of my body-weight, or 39 pounds, divided by two because on the pullover you use the handles, or 19.5 pounds.
At level three, it's 22 percent, or 57.2 pounds, divided makes 28.6 pounds, a difference of nearly 10 pounds, which doesn't sound like much until you're talking about an exercise like a straight arm pullover, and an increase of nearly half again, or close to a 50% increase in resistance, and since it's like a cable pullover, resistance actually spikes, bio mechanically speaking, right about where a dumbbell pullover eases up.
I though about using just one handle, but that would quarter the resistance, to 14.3, actually lower than level two resistance.
Hmmmm.
maybe free weights or tubes would be better
