House Hold Wiring
House Hold Wiring
Postby Spadinator » Tue Nov 28, 2006 7:41 pm
I am baffled....as is my electrician!
While sitting watching the Utah Jazz game last night the lights in the kitchen, dining, and living room all flickered and went out. The GFCI's in the bathroom and kitchen are also out. Check the breakers...nothing tripped. Kitchen GFCI is warm to the touch. Now here is the baffled part.
Kitchen and Bathroom GFCI are on circuit 3 A & B. Lights are on 7 A& B. No power on circuit 7 breakers (not tripped). One hour later all power returns on all circuits. At the recommendation of the electrician....all GFCI's replaced.....breakers on circuit 7 replaced...no idea what caused it.....any clues?
Never do anything you don't want to explain to the paramedics.
Spadinator
Images: 47
Postby rbeemer » Tue Nov 28, 2006 7:53 pm
I do not know what caused it but GFCI outlets do go bad. I had a new circuit put in my garage to run my woodworking tools and when it is cold out, I turn my mini-lathe or table saw on it pops the GFCI outlet and the breaker is fine.
Rick
If ducks had scales, would fish quack?
rbeemer
Postby Spadinator » Tue Nov 28, 2006 8:01 pm
I agree with the GFCI going bad but what is wierd is the light circuit going dead with out the breakers tripping. They are not even attatched to the GFCI's.
Spadinator
Images: 47
Postby rbeemer » Tue Nov 28, 2006 8:26 pm
Not necessarily true that the lights are not wired to the GFCI's. My lights in the computer room are not on the same circuit as the wall plugs. If your electrical genius is like mine who knows how they wired the place. THe circuit could go to your GFCI first and then to your lights, explaining why the kitchen one got hot.
Rick
rbeemer
Postby anonymous2 » Tue Nov 28, 2006 8:37 pm
Check the main panel,or GFIC for a loose netural wire for circuit involved. GFIC trips because of surges to netural side. A warm GFIC may mean a back feeding current through the ground. Lack of a neutral may have prevented GFIC from tripping . Some breaker finder signal generators have a circuit testers built in the generator half that may show circuit problems.
pateardropper
anonymous2
Postby madjack » Tue Nov 28, 2006 10:44 pm
...no joke...UFO's...really, they do that ya know...ya haven't noticed any itching in your navel have ya... :o :D ;)
Postby Ira » Tue Nov 28, 2006 11:27 pm
I was gonna say ghosts.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby GHOSTSSX » Wed Nov 29, 2006 12:00 am
Hello???
GHOSTSSX
Images: 35
Postby madjack » Wed Nov 29, 2006 1:28 am
GHOSTSSX wrote:Hello???
...is anybody in there?????................................... 8)
Postby asianflava » Wed Nov 29, 2006 1:31 am
The Chupacabra did it!
asianflava
Postby BILLYL » Wed Nov 29, 2006 5:53 am
No I agree with Madjack -
Utah = UFOs
It was clearly UFOs :oops: :oops:
Bill
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby Ira » Wed Nov 29, 2006 6:34 am
The way his electricty is behaving, it sounds like I did the wiring.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Steve_Cox » Wed Nov 29, 2006 8:07 am
Circuits 3 & 7. Both odd numbered breakers on the right side of the panel. No trips on GFI's or any breakers. Could it have been one leg of the 220V coming into the house had a power interuption? If you can't explain it, you can always blame the power company. :D
Steve_Cox
Images: 196
Postby Spadinator » Wed Nov 29, 2006 8:59 am
Steve_Cox wrote:Circuits 3 & 7. Both odd numbered breakers on the right side of the panel. No trips on GFI's or any breakers. Could it have been one leg of the 220V coming into the house had a power interuption? If you can't explain it, you can always blame the power company. :D
Yep.....the electrician said probably a power surge.....all parts replaced now.....the house has been exorcised and the tin foil doubled in the attic!!!!! :roll: :worship:
Spadinator
Images: 47
