SkipperSue wrote:Chaotica, I think you have a snake? I have a problem with my ball python from her last shedding. One of her eyes didn't get shedded off, am I worrying for nothing? She's about 2 1/2 years old now, name's marley.
The processes of shedding, or sloughing, usually take about 7-10 days to complete. You'll first notice that your Ball Python's belly is getting a pink color. Once you notice this, it's best advised to not handle your snake. Shortly after noticing the belly getting pink, you should see the eyes begin to look foggy and the snake's colors begin to dull. After 5-6 days of this, things begin to clear up. A few days after the clearing, your snake will find something rough and rub against it. Ideally your snake should be able to shed in one full piece, which comes off inside out, like when you pull off your sock. If your snake doesn't happen to get it off in one piece, that's a sign that you are not providing exactly the right environment. It may be too dry in the tank, or your snake may be a little dehydrated. The two problem areas you should watch out for, if it didn't slough in a single piece, are around the eyes, and the tip of the tail. If the eye caps did not shed off, your snakes eye(s) will have a foggy silver look to them. To help the snake shed off those last few bits of skin, you can try soaking it in a luke warm/cool bath for a half hour or so. Then gently dabbing it with a warm damp cloth. Placing the snake in a damp cloth bag for awhile sometimes helps also. Some people have had luck dabbing the eye's with a cotton swab that's been moistened with baby oil. If you cannot get the eye cap(s) off, I wouldn't worry too much, and pay extra attention to the humidity level and the hydration of the snake through it's next shed cycle. Most likely the eye caps will come off with the following slough. If after two shed cycles, the eye caps are still intact, a trip to the vet may be called for.
SkipperSue wrote:I've tried a few while she's been in her cage but the glass has too much reflection.
kirtsjc wrote:OOO! OOO! OOO! Ohhh!
I wanna see pics of her eating, OOO!
