Am I to fat
Am I to fat
Postby glassice » Thu Mar 01, 2007 11:53 pm
yes :cry: But I have to pick up a piece of steel that is 6" by 5 feet by 12 feet I will have to go down the grapevine in SO Calif going north from apple valley .My truck is a f 350 .what do you think will it be safe on a u hall trailer
It is not the return ON my investment that I am concerned about; it is the return OF my investment
glassice
Postby madjack » Thu Mar 01, 2007 11:58 pm
JHC :shock: :? ...am I reading that right...6 inches thick by 5 feet by 12 feet...that is not a "piece of steel"...that is armor plate...for a battleship!!!! Can you even get a U-Haul rated for that much weight...do you know what it actually weighs...
Postby robfisher » Fri Mar 02, 2007 12:07 am
You better check that out. Just going from memory I think that plate would weigh about 15000 pounds. I don't know of any uhal trailer you would want to put that on. If I remember right 1 square foot of 1 inch thick steel weighs about 41 pounds.
robfisher
Postby glassice » Fri Mar 02, 2007 12:07 am
yes that Right. I have no ideal what the weigh is the air force Capitan said they will load with a fork lift
glassice
Postby madjack » Fri Mar 02, 2007 12:19 am
robfisher wrote:You better check that out. Just going from memory I think that plate would weigh about 15000 pounds. I don't know of any uhal trailer you would want to put that on. If I remember right 1 square foot of 1 inch thick steel weighs about 41 pounds.
Rob, you are right...I looked it up and basically 15,000 pounds is correct or near enough for figuring purposes...
Glass...you had better check very carefully the load capacities of any trailer and truck you use to move that much weight or CRASHBAMBOOM!!!!!
Postby glassice » Fri Mar 02, 2007 12:19 am
Thank you. wont be puting on a Harbor Freight trailer without adding air to the tires
glassice
Postby madjack » Fri Mar 02, 2007 12:21 am
glassice wrote:Thank you. wont be puting on a Harbor Freight trailer without adding air to the tires
....just remember the tagline in your signature................................... 8)
Re: Am I to fat
Postby Gage » Fri Mar 02, 2007 12:25 am
glassice wrote:yes :cry: But I have to pick up a piece of steel that is 6" by 5 feet by 12 feet I will have to go down the grapevine in SO Calif going north from apple valley .My truck is a f 350 .what do you think will it be safe on a u hall trailer
I think I would go west on 18 to 138 to 14 and then north to 58 and on down to Bakersfield through Tehachpi. It'll be quicker than going down 14 to the I-5 and then to Bakersfield via the Grapevine. Coming across 138 you'll also come within a mile of my place. Yea, big deal. :lol:
Image Image Image
Gage
Images: 28
Postby robfisher » Fri Mar 02, 2007 12:27 am
I noticed we spelled U-Haul three different ways. Good job MJ for getting it right the first time! I learn so much from this board. Thanks for the work you guys do in keeping it available to us. Rob
robfisher
Postby Gage » Fri Mar 02, 2007 12:29 am
You notice I didn't even use the word U-Haul. Am I not the smart one. ;)
Image Image Image
Gage
Images: 28
Postby glassice » Fri Mar 02, 2007 12:34 am
thanks gage I like to see your cabnets .now if i can put on your tear and you could drop off on your way to the dam gathering that work I think I will have a trucking co. pick it up
glassice
Postby Gage » Fri Mar 02, 2007 12:45 am
glassice wrote:<snip>
Good idea if I may say so myself.
Image Image Image
Gage
Images: 28
Postby madjack » Fri Mar 02, 2007 12:45 am
glassice wrote:...I think I will have a trucking co. pick it up
...probably a VERY smart move :thumbsup: .......................... 8)
Postby PaulC » Fri Mar 02, 2007 12:46 am
I've been trying to do things righ for years. Just never seem to quite make it though :lol:
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby madjack » Fri Mar 02, 2007 12:48 am
Paul, I have noticed that every time I get it all righ, I find that everything has shifted to the lef :D :lol: ;) ........ 8)
