Removing decals from cars?
Postby Ira » Wed Aug 01, 2007 7:16 am
What's the best stuff to use to get rid of that cursed gummy goop?
There's something yellow in a small bottle that's called "Goop" something, right?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Nobody » Wed Aug 01, 2007 7:36 am
Goo Gone, get it at the 'accursed' Wal Mart ;)
Harvey -
Nobody
Images: 342
Postby SteveH » Wed Aug 01, 2007 7:57 am
And if you need a lot of it, go buy some automotive acrylic enamel thinner....it's the same thing and cheaper by the gallon.
SteveH
SteveH
Images: 42
Postby elmo » Wed Aug 01, 2007 7:58 am
Hair dryer/heat gun...heat up and pull or wipe off!
If you use the chemical type stuff...put it on somewhere you can't see to make sure it doesn't react to the paint. Under the hood is always a good spot.
It's scary when you start making the same noises as your coffee maker.
elmo
Images: 216
Postby Joseph » Wed Aug 01, 2007 8:27 am
I use lighter fluid.
Joseph
Joseph
Teardrop Pirate
Postby apratt » Wed Aug 01, 2007 8:31 am
3M make a product called adhesive remover it come in a spray can. It works good and don't hurt the paint finish.
Arthur,
ASL spoken here
apratt
Images: 16
Postby khutson » Wed Aug 01, 2007 8:47 am
All the suggestions above will work. Be sure to NOT do it with the sun beating down on the area your working on. GooGone stuff will react with a lot of different kinds of paints so tread lightly. In my shop we only use products made for decal adhesive removal.(I can't afford to re-paint a customers car) A local sign supplier or shop may have what you need and sometimes you can get it at Autobody supply places. I've even seen some at the box auto part stores. I would give you a name but I always seem to get somthing different everytime I buy some.
Keep it out of the sun
Don't use any sharp blades to help with removal(Chemicals listed will temp soften your paint and it's easy to dig to far down in to your paint and create problems later.)
Lot's of clean rags or paper towels.
Rubber gloves to protect your hands.
Lot's of elbow grease! Depending on the brand of glue used on the decals. Some come off real easy and some just don't want to come off at all.
Good luck!
Ken
Our build blog, We try to keep it current! Check it out!
http://kennoel.blogspot.com/
khutson
Postby Sonetpro » Wed Aug 01, 2007 8:49 am
Joseph wrote:I use lighter fluid.
Joseph
Yes lighter fluid is cheap and will take any goo off.
Sonetpro
Images: 107
Postby Kurt (Indiana) » Wed Aug 01, 2007 8:50 am
WD-40?? :thinking:
CRA2023 Web Site
"Wall of Fame 2011-2021"
Kurt (Indiana)
Images: 178
Postby Ira » Wed Aug 01, 2007 9:03 am
khutson wrote:Keep it out of the sun
In south Florida in August?
Thanks for the replies, guys. The lighter fluid route seems to make the most sense for a first attempt.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Jst83 » Wed Aug 01, 2007 9:53 am
Ira wrote: The lighter fluid route seems to make the most sense for a first attempt.
If you add a lighter to that it will take it right off. :lol:
Jst83
Images: 215
Postby doug hodder » Wed Aug 01, 2007 10:37 am
apratt wrote:3M make a product called adhesive remover it come in a spray can. It works good and don't hurt the paint finish.
Ira, I've used this stuff that Arthur mentions. I really works good, remember though, you may have some "ghosting" left on the paint from the removal of the stickers. Caused by sun fade on the paint. Doug
Postby caseydog » Wed Aug 01, 2007 10:45 am
Hey Ira, I know YOU have used this stuff before, and I use it for removing adhesives on cars, too.
Bestine.
Very safe on the paint. Just be sure to wax after you get the goop off.
My build journal is HERE
caseydog
Images: 515
Postby Ira » Wed Aug 01, 2007 11:41 am
Bestine? Did I sniff it?
It's white, so maybe the fading issue ain't such a big deal.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby SkipperSue » Wed Aug 01, 2007 1:11 pm
I give the WD-40 a second vote, that's all
this stuff is good for anyway. :thinking:
Skipper
SkipperSue
Images: 114
