Concrete Acid Stain
Concrete Acid Stain
Postby cleave » Sun Sep 09, 2007 10:48 pm
Has anybody here ever used this stuff? I'd like to do our basement floor this fall and I'm having a hard time finding the products necessary for this. Any help would be appreciated.
Thanks!
cleave
Images: 34
Postby madjack » Sun Sep 09, 2007 10:55 pm
errrr, what stuff???? If you are going to use an acid to clean the concrete and it in a basement(or anywhere else) be sure there is PLENTY of ventilation....
Postby Arne » Mon Sep 10, 2007 7:11 am
do you have a drain in the floor? YOu will have to rinse it very, very well after the application...
Some acid washes just etch it so paint will stick... you may also have to be sure it will 'degrease' as well..
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby cleave » Mon Sep 10, 2007 7:48 am
It's actually a "decorative" finish for concrete floors.
"Acid staining is not a dyeing or pigment base coloring systems but a chemical reaction. A mixture of water, salts and acid is applied to the concrete surface and later neutralized by a basic solution, of ammonia and water. Although some manufacturers recommend using baking soda and water, this process increases efflouresence and alkali problems once the surface is sealed.
This chemical reaction with the existing minerals in the concrete creates new colors on the concrete surface. Due to inconsistencies in the surface of concrete, acid staining creates a variegated or mottled appearance that is unique to each slab. The thickness of this color change ranges from 1/16th to 1/32nd of an inch."
cleave
Images: 34
