http://epw.senate.gov/public/index.cfm? ... 5D0842FED8
SFC Hall wrote:never trust a politician
The key to separating scientific knowledge from belief is that science can be demonstrated. We may never have good enough error bands on the data about global temperature data; thus it is something that is just not knowable. Opinions on things unknowable are called beliefs. Because of the inapplicability of the scientific method when dealing with open systems, opinions on global warming are beliefs akin to a sort of religious view and not scientific fact.
"Climate science" as reported in the press is not really science. In real sciences the scientists first job is to prove himself wrong - that is to list the numerous way that the results my be in error and how the conclusions are limited. No forthright "bending over backwards" efforts are made by the global warming proponents. Instead, there are efforts to state things in emotional terms and a disturbing pattern of data errors and omissions. When claims are made dealing with an open system using correlations of data without knowable error bands, it fails to be science. There is no way to separate out the increased use of irrigation and the resulting increase of low altitude water vapor (very much a green house gas). Could changes of global low altitude humidity be a plausible competing theory? The correlation of temperature and variations of solar output is ignored.
I failed to see even an estimate of the amount of error of natural emissions of CO2 in the bandied documentation. Using real science, means you figure the answer and then you do the hard part of calculating the minimum, maximum, and probable errors. It is not possible in this case to even have hard numbers on CO2 venting - thus we are again not looking at science, but only estimates and speculation. Attaching numbers to speculation does not elevate it to science.
