Tips on pumping gas (GOOD)
Postby 4123 » Wed Mar 05, 2008 6:01 pm
This letter was sent to me from my nephew, who has worked in the oil industry for over 30 years:
TIPS ON PUMPING GAS
I don't know what you guys are paying for gasoline.... but here in California we are also paying higher, up to $3.50 per gallon. But my line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every gallon...
Here at the Kinder Morgan Pipeline where I work in San Jose, CA we deliver about 4 million gallons in a 24-hour period thru the pipeline. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role. A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3) stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom.
~~~Ron & Olga Christianson~~~
http://www.museumphones.com
"Consider It ALL entertainment"
Images: 50
Postby satch » Wed Mar 05, 2008 7:52 pm
Dude, with todays prices, this advise could save people alot of cash. Thanks :applause:
If it itches. scratch it
Rick
satch
Images: 63
Postby PaulC » Thu Mar 06, 2008 2:30 am
That little letter has been doing the rounds for a couple of years now. Most, if not all, of it is highly questionable. For example, ground temperature at about 6' only varies by approx 1-2f in a 24 hour period.
Believe what you like but be a little pessimistic with this type of "professional" information.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
I agree
Postby eamarquardt » Thu Mar 06, 2008 12:42 pm
PaulC wrote: "Believe what you like but be a little pessimistic with this type of "professional" information."
I agree with his comments, particularly about the temperature below ground not changing much. I like not being the only cynic/skeptic out there.
Gus
eamarquardt
Images: 150
