Heat resistant--help
Postby ksragwooler » Fri Mar 07, 2008 4:02 pm
We are currently doing a rebuild on a 1955 Hobbyline canned ham. Around the stove is some type of (asbestos, I'm sure) fiber board. Between the stove and the wood. Any one have an idea as to what to use in its place now?? Need some heat resistant. Thanks a bunch in advance....LaVern & Carolyn
ksragwooler
Postby Miriam C. » Fri Mar 07, 2008 4:09 pm
There are some products out there and some are expensive. Try google and see if there are some new products. This is the one I found some time back but it may be over kill for your needs.
http://www.adlinsulflex.com/fire-blankets/
thanks
Postby ksragwooler » Fri Mar 07, 2008 4:42 pm
I just didn't know what to search for. found a product that looks like it is coming from race car parts. that was by searching for heat resistant mats. It was expensive also! lol But, looks like the old stuff had given out and this stove must get hot as the wood was alittle blackened! Better to be safe (even if expensive) than sorry!! I can just see me now.......tearing out of the little trailer and smoke billowing out the door! lol
ksragwooler
Postby Miriam C. » Fri Mar 07, 2008 4:52 pm
;) You might read this too:
http://www.intlbarrier.com/products/bla ... ations.htm Has some interesting thing. Also you use steel as along as you don't intend to leave the stove blazing at it for a long time.
Postby AmyH » Fri Mar 07, 2008 6:28 pm
If you have a pottery/ceramics supply house near you take a look at refractory blankets. That should do the trick.
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Postby dmb90260 » Fri Mar 07, 2008 6:29 pm
The stove on my Kenskill was set in plywood. There probably is insulation in the stove but nothing extra added to the trailer walls.
Dennis
Join the Kenskill Karavan at:
http://autos.groups.yahoo.com/group/kenskill_karavan/
Real Men cook with Black Iron
The Buzz In the Dale: The Buzz In The Dale
dmb90260
Titanium Donating Member
Images: 134
Postby 48Rob » Fri Mar 07, 2008 7:04 pm
Hi,
If the current (existing) heat shield isn't damaged, it can be reused.
Asbestos is not dangerous unless it is crumbling or otherwise shedding fibers.
People inhale more asbestos fibers removing perfectly sound asbestos products than they ever would have if the product was simply left alone. :thinking:
Rob
48Rob
fire/stove
Postby ksragwooler » Thu Mar 13, 2008 5:09 pm
The stove sits in a plywood cubbyhole but when we pulled it out it had this fiber/cardboard insulation type stuff between the stove and plywood. I assume this is because of the heat from the stove. Assume it would be best to put something back around it before we set the stove back in. Lots of good ideas, we will try one and see what happens! thanks.
ksragwooler
Postby Elumia » Fri Mar 14, 2008 1:56 am
maybe you could check out some of that 1/4" hardboard backer intended for tile. Should be heat resistant. comes in 3'x5' sheets I beleive.
Mark
Elumia
Images: 15
Postby TPMcGinty » Fri Mar 14, 2008 4:32 am
Maybe a store that sells fireplaces would have something you could use. Just a suggestion.
Tim
TPMcGinty
Images: 146
Postby Larwyn » Fri Mar 14, 2008 6:40 am
I used mats inteded for under a grill to protect the floor and wall around Lanza's kiln. Got them at Lowes in the grillin' section.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
