need help with freon
Postby S.A.Mike » Tue Jul 01, 2008 11:22 am
I have an old coca cola cooler that needs a compressor. It uses freon 12.
Can I replace it with a compressor from a window A/C that used freon 22?
Thanks Mike
S.A.Mike
Postby SkipperSue » Tue Jul 01, 2008 12:54 pm
Yes you can, as long as the output is about the same. I wouldn't use 134A freon in it though unless it's a fairly new one. The old oils in the compressor doesn't like that new freon. (134A)
Skipper
SkipperSue
Images: 114
Postby S.A.Mike » Tue Jul 01, 2008 2:23 pm
Thanks Skipper, now I hope I can do the solder job needed.
Mike
S.A.Mike
