Help with Google Earth
Postby Creamcracker » Mon Sep 08, 2008 3:11 pm
A couple of weeks ago someone posted a link to download KOA campsites as a module to Google Earth. I did that, didn't like it and then removed that module. Since then I can see nothing on Google earth. I just have a black background with some yellow lines showing up now and then. I even removed Google earth and then reloaded it but still the same. I have tried different combinations with the features/layers etc but nothing seems to make any difference! Any suggestions anyone?
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby DrCrash » Mon Sep 08, 2008 3:35 pm
Uninstall it from your program list. Then reboot the computer and reinstall the program. Should work fine after that.
Mine did the same thing and that was my fix.
DrCrash
Images: 51
Postby Creamcracker » Mon Sep 08, 2008 3:59 pm
DrCrash wrote:Uninstall it from your program list. Then reboot the computer and reinstall the program. Should work fine after that.
Thought that was going to work esp with the reboot but nope! Any other suggestions anyone?
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby Wimperdink » Mon Sep 08, 2008 6:27 pm
should be as simple as uninstalling, removing GE directories and registry entries and a reboot before reinstalling. I dont want to go into a lot of detail on the registry entry deleting. You can cause some serious damage if you dont understand the registry.
Wimperdink
Images: 33
Postby toypusher » Mon Sep 08, 2008 6:29 pm
Is the program gone from your 'add/remove' list? If not, you could try to find a copy of the JV16 Power tools and remove it with that. It will let you clean out the registry too.
toypusher
Images: 324
Postby Creamcracker » Mon Sep 08, 2008 6:32 pm
Wimperdink wrote:should be as simple as uninstalling, removing GE directories and registry entries and a reboot before reinstalling. I dont want to go into a lot of detail on the registry entry deleting. You can cause some serious damage if you dont understand the registry.
Nope none of those, I had to go into options and then change one of them to TOOLS>OPTIONS>GRAPHIC>DIRECT X that took care of it ....looks like somehow when I downloaded the KOA module it reset the graphics mode....anyway it's fixed now.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby Creamcracker » Mon Sep 08, 2008 6:33 pm
toypusher wrote:Is the program gone from your 'add/remove' list? If not, you could try to find a copy of the JV16 Power tools and remove it with that. It will let you clean out the registry too.
Yep when I removed it ...it was gone....Kerry see entry above. I fixed it.
Philip
Creamcracker
Teardrop Graduate
Images: 142
