WarPony wrote:Jules, I'm confused by your post. What works and what doesn't? It sounds like a bad ground on the dash circuit but could also be corroded (SP) battery connections or a weak battery.
Look at the battery connections first, I've seen alot of problems associated with rotten battery terminals. They may look okay to the eye but if you loosen them and see what's underneath.............
Computer controlled cars/trucks are VERY touchy, as far as battery voltage is concerned. A "fuzzy" battery post can cause alot of goofy driveability problems.
Jeff
oklahomajewel wrote:
My instrument panel isn't lighting, neither are my parking lights or tail lights.
Brake lights , head lights, turn signals ...those are all fine.
Fuses and bulbs are fine.
Thanks y'all !!!!
Nitetimes wrote:Even if they look good change the fuse for them. They are almost always on the same fuse and the fuse is nearly always the culprit.
