One use for a 20# propane cylinder
Postby planovet » Tue Dec 23, 2008 5:24 pm
Man melting snow with blowtorch ignites home
He wanted to clear back porch, instead he's got $30,000 in damage
NEW BEDFORD, Mass. - Fire officials in New Bedford, Mass., say a man using a blowtorch to melt ice on his back porch ended up setting his house on fire, causing up to $30,000 in damage.
Fire Capt. Scott Kruger tells The Standard-Times of New Bedford that no on was injured during Monday's incident at the three-story home.
Kruger says the man was using a torch hooked up to a 20-pound propane cylinder. He got too close to the building's wood frame and ignited the vinyl siding. The fire quickly spread into the building's second- and third-floor apartments.
It took 25 firefighters to subdue the blaze that damaged bedrooms in the upstairs units, and caused damage to the structure and wiring.
The homeowner will not be charged.
ImageMark (& Cindi)
planovet
The Cat Man
Postby toypusher » Tue Dec 23, 2008 5:27 pm
DOH!!! :?
toypusher
Images: 324
Postby madjack » Tue Dec 23, 2008 8:07 pm
...UHGGG-fire hot-wood burn...sheeeesh, some peoples kids :shock: :? ...................... 8)
Postby starleen2 » Tue Dec 23, 2008 11:13 pm
Maybe he should have use a BIGGER torch that way the INTENSE heat would melt the snow quicker and would not have to spend so much time trying to get the wood to ignite ... geez
starleen2
5th Teardrop Club
Postby Kevin A » Tue Dec 23, 2008 11:36 pm
Almost a candidate for the Darwin Awards. :lol:
Kevin A
The other guy
Images: 289
Postby Jst83 » Wed Dec 24, 2008 5:36 am
Kevin A wrote:Almost a candidate for the Darwin Awards. :lol:
Almost :thinking: I'd say for sure a candidate
Jst83
Images: 215
Postby planovet » Wed Dec 24, 2008 9:03 am
Actually the Darwin Awards are given to people "who ensure the long-term survival of the human race by removing themselves from the gene pool in a sublimely idiotic fashion." While this person did not remove himself from the gene pool, he definitely showed that he swims in the shallow end.
Here is a Darwin Award candidate for 2008:
(14 April 2008, Texas) A contract worker was hired to install reinforcement bars on a communications tower near Camp Bullis. He was wielding power tools high above the ground, when two other workers saw him lean back and fall 225 feet to his death. Turns out, the man had loosened the bolts on the bar to which he was attached.
ImageMark (& Cindi)
planovet
The Cat Man
