Micro469 wrote:You don't say if it's a gas or electric heater. One thing you can try is turn the heater off , shut off the cold water inlet and drain the heater. Turn the cold water inlet back on, and if it fills up the blockage is in the hot water outlet...................If it doesn't fill up, then the blockage is in the cold water inlet.......... Pipes didn't freeze did they????
Wimperdink wrote:I appreciate the responses....
I removed it and took it outside to mess with it. Since there was so much crud in the bottom, and the chunks were big enough to not go down a garden hose, I figured I had nothing to lose. I took it outside and with both elements out I was pouring the crud out of the element holes. After getting a bunch of that out I looked at the water inlet hole. It was blocked so solid I couldnt blow air through there. I set it by the garage and went and bought a new one. I need a hot shower tonight.Thanks for the help folks. I know this is a teardrop board, but there's a lot of enterprising people here and I knew someone would have ideas. Thanks.
