Oasis Maker wrote:I have both an evap system and air conditioner on my roof. Even though I've lived in this house for 6 years, this is my first time using the evap system. Evap systems work really well in hot/dry climates. As you can see by my Avatar, I live in AZ and we are just about ready to enter monsoon season which is pretty humid (by our no humidity standards).
My question is, how long do you hold out using your evap system if you are in a similar environment (or not)? Do you try and stretch it out deep into summer? I hear evap systems are pretty unbearable beyond July here and I'm getting a little taste of that today (108). Might have to climb up on the roof to insert the damper and make the switch to the air conditioner, but I sure like the idea of saving big bucks.
Scott G.
Dan & Julie CO wrote:I am from Albuquerque and what I did during rainstorms is turn the water pump off so the pads are not over saturated. it seemed to help
when I lived in Tucson and it was 110 degrees and the afternoon monsoon
rolled in well it does get sticky. try it, see if it helps
JenniferandPups wrote:We have a traveling "swamp cooler"... it's on wheels and rolls from room to room. It makes a substantial difference in the temperature of the room! We live in an old house, so no a/c... the swamp cooler helps a bunch. Everyone is always amazed at how cool it is inside.
We are in Colorado; it has been unseasonable cool and rainy this year, so we haven't even dug it out yet... but we will when it hits 90 or 100!
High Desert wrote:We just got a new one today. Its one of the portable indoor types, works nice. We live in a similar climate but not with the sustained high temps you get. We've had them in the past and used them all summer, the added humidity combined with a couple of well positioned fans keeps life bearable even on the 100*+ days here. As for when, until it's pushing the 90s we feel it really isn't needed. And the reduced operating cost makes for a happier budget
Edit- just checked and we are at 11% humidty right now. THe swamp cooler is feeling nice
ssrjim wrote: It is easy to know when to switch. Just watch the news, I watch 15. They tell you when it is time to switch. Pretty much for the next month it will be A/C.
emiller wrote:There are less and less evap coolers put on houses anymore with todays A/C systems. On our old house we did away with the cooler and replaced the A/C system which was made by Chrysler. The new A/C system costed about $4,000.00 and we saved that much in just a few years of use. Coolers take too much servicing and Phoenix metro area isn't as dry as it once was.
Scott usaully when the cooler stops being comfortable you switch to A/C.
Oasis Maker wrote:High Desert wrote:We just got a new one today. Its one of the portable indoor types, works nice. We live in a similar climate but not with the sustained high temps you get. We've had them in the past and used them all summer, the added humidity combined with a couple of well positioned fans keeps life bearable even on the 100*+ days here. As for when, until it's pushing the 90s we feel it really isn't needed. And the reduced operating cost makes for a happier budget
Cool. (Pun intended). Since you've had these portable units in the past, what models are you highest on?
Scott
