by Laredo » Sat Dec 26, 2009 2:48 pm
Several years ago I got a lovely ceramic "candle" -- you plug it in and it melts the interior wax. No wick, so no aerosolized lead fragments from burning the wick. This year, though, the scent had entirely departed the wax (it came with one designed to infuse a whole room with 'fresh linen' scent).
So I turned it on and let it melt and then poured it off, cleaned the interior of the vessel and added (because the wax meant for it is not currently available) about a dozen tealight candles that I hulled out of their little aluminum cups and deprived of their wicks. I melted the first half-dozen in a tin can over a very low flame, poured the wax into the ceramic vessel, added the rest of the (pumpkin spice) candles and plugged it in. Result? house smells really nice.
The candles are way stronger burned on their own.
For your candle in a jar, try this:
Set the jar in a heavy (CI if you have it) 8'' skillet with 1/2'' of water in it. Bring the water to a simmer and let the wax melt in the jar (the skillet behaves like the bottom of a double boiler). Once it's melted the wax will level out again. Take about a 12''-14'' length of heavy cotton string and rub it between buttered or safflower-oiled fingers, then double it up and twist it to create your wick, which you slip into the salvaged fitting off the bottom of the original wick (weighted, if need be, with a couple of pinch-on fishing weights the size of bbs).
Suspend that into the bottom of the wax with the pencil method already described and set the jar somewhere to cool slowly. You can repeat this up to a dozen or so times, until the wax evaporates down. The butter / oil on the string increases its ability to light and hold a flame but won't change the smell of the candle.
IF that sounds like too much trouble, get yourself a "mug warmer" and set the jar on it, turned to low, and just don't worry about the wick.
