by Woodyperk6 » Thu Dec 31, 2009 2:46 pm
He doesn't have a blower or any other forced air device. When I had the pan off before I cleaned it up really well and did not see any signs of damage or cracks in the pan. The first time the gasket blew out it was on the right front corner of the pan. This time it blew out about half-way down the right side. The truck is not running hot & does not smoke or burn any oil. I used a 3M gasket sealer I have used many times over the years. The gasket is a rubber gasket from Ford that has metal inserts in the bolt holes so I don't think I crushed the gasket out. The pan bolts are still tight. I'm kinda at a loss right now.
Woody & Tammy
One day closer.
