htmldoc
htmldoc
Postby toypusher » Mon Feb 28, 2011 8:41 pm
Someone on this board has a copy of htmldoc I believe.
They were making pdfs of build threads at one point.
I would like some online documentation converted into some kind of document that I can print out or use offline at least.
If I can only find the person who has the program.
toypusher
Images: 324
Postby chorizon » Mon Feb 28, 2011 9:08 pm
I have pdf995 that "prints" a pdf.
H&R Block was nice enough to send it to me a couple of years ago with their tax return software.
Oh! It looks like its downloadable on the net as well.
Works great. Acts as a printer, but creates pdfs.
Is that what you were looking for?
chorizon
Images: 94
Postby caseydog » Mon Feb 28, 2011 9:31 pm
I'm not exactly sure if this will be any help, Kerry, but the Mac OS turns everything into a PDF for printing, and any screen can be made into a PDF from any program. I also have Acrobat Professional, if that helps.
CD
My build journal is HERE
caseydog
Images: 515
Postby bve » Mon Feb 28, 2011 11:51 pm
Kerry it's me that uses htmldoc. Do you have a url for the page/documents that need conversion?
Burke
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
Postby toypusher » Tue Mar 01, 2011 6:14 am
Burke, I was hoping you would see this, I just could not remember who had the program.
It would be fantastic if this documentation could be easily be made into a PDF or any sort of document for offline use.
And if it will be too much trouble or effort, please do not even try.
http://www.phpbb.com/support/documentation/3.0/
Thank you so much.
toypusher
Images: 324
Postby toypusher » Tue Mar 01, 2011 6:17 am
caseydog wrote:I'm not exactly sure if this will be any help, Kerry, but the Mac OS turns everything into a PDF for printing, and any screen can be made into a PDF from any program. I also have Acrobat Professional, if that helps.
CD
Glenn,
I want a whole online documentation converted - hopefully without going through page one at time and then doing something to convert it.
Here is what I am looking to convert: http://www.phpbb.com/support/documentation/3.0/
toypusher
Images: 324
Postby bve » Tue Mar 01, 2011 8:40 am
toypusher wrote:It would be fantastic if this documentation could be easily be made into a PDF or any sort of document for offline use.
Kerry, do you want to be able to print it for reading away from the computer, or just view it without a connection?
There are other *nix tools that can be used in conjunction with htmldoc that make either task fairly easy.
Burke
KISS > COMPLEX
bve
Images: 98
Postby toypusher » Tue Mar 01, 2011 11:33 am
I would ultimately like to be able to print it, but just having it offline would be good too.
toypusher
Images: 324
Postby bve » Tue Mar 01, 2011 11:34 am
Well, that was pretty darn easy...
I did some searching on the phpBB developer web pages, found that they have all the scripts required to compile their documentation into any format including pdf, using docbook, xml and xslt. So I downloaded the source files for the documentation, installed fop and compiled it into a pdf in under 5 minutes.
The file is about 1.3MB so I just need to know where you want it sent - you can PM me if you prefer.
Burke
KISS > COMPLEX
bve
Images: 98
Postby toypusher » Tue Mar 01, 2011 11:35 am
bve wrote:Well, that was pretty darn easy...
Not sure if I can received that size in my email, but you can try that first
[email protected]
thanks
toypusher
Images: 324
Postby bve » Tue Mar 01, 2011 11:57 am
Sent it, let me know if you need anything else.
Burke
KISS > COMPLEX
bve
Images: 98
Postby toypusher » Tue Mar 01, 2011 12:09 pm
bve wrote:Sent it, let me know if you need anything else.
Got it and replied to your email.
Thanks you so much for the help with this.
If I can help you with anything, just let me know! :)
toypusher
Images: 324
