This is an old pic. please excuse the mess.
48Rob wrote:I'm with Gus,
You can probably do so without a permit, but better to be safe.
From the picture showing what looks like the home furnace in the rear, you should also have a heating and air expert make sure you won't have a problem with return air to the unit if you wall the area off (may have an issue now, being in the garage where fumes may be drawn in?
Probably other issues that should be considered.
Doing the work yourself is a good way to save money, but getting professional advice before you start is very inexpensive compared to potential consequences.
Rob
LDK wrote:I was planning on making it a weight bearing wall with a double top plate and a 2x6 door header. Overkill, probably but it would make me feel better.
glenpinpat wrote:If I got a permit every time I did something to one of my properties I would be broke. The wall will never be a load bearing wall as the rafters are built to code and will support themselves.
LDK wrote:glenpinpat wrote:If I got a permit every time I did something to one of my properties I would be broke. The wall will never be a load bearing wall as the rafters are built to code and will support themselves.
I wonder how big the header is over the garage door? My wife said everything was done right according to the inspector. I guess I'm just alittle worried because we had to fix several things about the garage. I believe the builder had several different contractors to do different things. We had a garage roof leak where the side wall meets the house in the back and when me and my brother in law re-roofed it, we found out it didn't have any roof flashing. We had to replace a stud and some drywall. They also didn't use any house rap before they put the vinyl siding on. My next project is to re-side it. Do I need a permit to do that??
LDK wrote:The house is 26 years old and the garage was built about 16 years ago. They didn't do any roofing except to only the garage part. we re-roofed the house/garage in 2008. You think they would at least slid some flashing under the roofing tabs before they put the vinyl siding on the sidewall.![]()
The roof is good and straight and no sagging but I hear cracking from time to time. I can even push alittle on the brick wall and hear cracking sounds. Thats why I want a wall, for the extra support.
Oh yeah, they didn't put any kind of ventilation on the garage roof and even the soffet doesn't have any vents. When we re-roofed it we had to cut a slot in the ridge and install a ridge cap. They half assed that garage and I really don't trust it.
