by charliehm » Sat Oct 15, 2005 12:09 pm
Doug,
A 50% posting rate speaks well for the forum. 10% is probably the norm in most other forums.
Also, think about the classes you've taken. Unless the circumstances were highly unusual, only a few students carried the bulk of the discussion. But that doesn't mean that the others weren't engaged or didn't benefit.
Ironically, one of the things that might be limiting participation is the wealth of information to be found and the fairly good search function there is to find it. Often when I have a question or comment that has arisen as I build my trailer, if I run a search before I attempt a post, I find that the question has already been asked and answered quite adequately several times over. For me to say anything more would be posting for the sake of posting, rather than moving the discussion forward.
I wasn't aware that spammers were aggressively culled, but I certainly appreciate the high levels of comraderie and low levels of "noise" to be found here. Thanks for the behind-the-scenes work.
Charlie
There are 3 ways of doing work, but you can only have 2 of them at the same time:
FAST and GOOD isn't CHEAP. CHEAP and FAST isn't GOOD. CHEAP and GOOD isn't FAST.
