Hamsterbite wrote:Got a question that has to do with tiny houses, but not on wheels so figured it was off topic, but there might be some crossover here.
I keep reading that most building dept's don't require a homeowner permit for structures less than 100 square feet. Does anyone know if this is pretty much universal? I understand that other rules still may apply, (such as min setback) depending on where you want to put it, and that anything with plumbing and electric needs to be permitted. Assuming all the other criterea was met, how do you go about calculating the square footage? Is it just the footprint area, or would they also include loft space and/or a second story? We're talking pretty rural and out of sight to anyone that wasn't trespassing.
Anybody?
I am "one of those type of people" in that I work for a city and oversee building inspection, planning and zoning, and code enforcement.
Most cities have zoning and building codes that do not require permits for accessory structures - sheds, storage buildings, etc. - if they are less than a certain size usually 100 or 120 square feet. This assumes there is no electrical or plumbing work in the accessory structure which would require permit(s).
The best advice as several have said is to contact your local jurisdiction. Believe me from my experience the adage of "better to ask forgiveness than permission" does not apply here. It is not usually city or county employees raising questions about your construction. Most often issues are raised by your neighbors or the over zealous HOA representative that contacts the mayor or councilman.
Better to find out before you start.
