GPS/Back Up Camera
GPS/Back Up Camera
Postby eamarquardt » Sat Mar 23, 2013 1:36 pm
Hi all,
Well, I've risen from the ashes again and got a bit done this week. My new Traverse has very limited visibility out the rear due to the small windows and how high the windows are. In addition I don't like twisting my head due to the pain it causes so I've screwed up a couple of times in the past and backed into things. So, given my desire to protect Suzy's investment in my new car I decided to add a back up camera. I bought Magellan GPS/Wireless Back up camera and installed it. Took three times to get one that worked. Not sure what the problem was but the third one works fine. I bought a pole mount, made a wooden plug (pictured is the prototype but I have a better final version to install) to fit into a cup holder, made a special mount to attach the display to the pole mount and now have the display in place. The only connection to the vehicle is the cigarette lighter plug so it's easy to move from one vehicle to the next. It's kinda cool to have a GPS displayed all the time as you can see the names of streets as you approach em.
103520
This is the camera that came with the unit. In addition there is a transmitter that the camera plugs into which transmits the view to the display when the back up lights come on (you have to connect the transmitter to the back up light wiring). This camera produced a good image in daylight but was useless at night so I bought a new camera with IR LEDs built into the unit. This camera was easy to install as all you had to do was unscrew two of the license plate screws, place the camera in place, and then replace the screws. The only additional step was to drill holes for the wiring through the license plate and the body of the truck.
103517
The new camera didn't mount as easily so I had to make my own mount. Here are two pictures of it. Note the recess for the wiring. This was required to allow me to use the holes I drilled for the first camera with the replacement. I made it out of a piece of aluminum I had hanging around. You can never have to much old metal around. It always comes in handy.
103515
Another view of the bracket. Note the extended flange I made. I thought it might be a good idea to protect the camera from being bumped as it's a bit vulnerable hanging out in the back.
103516
Here is the finished installation. What's really cool is that you can see the trailer ball in the display and back up to a trailer w/o any help. You can get so accurate all you have to do is drop the trailer hitch onto the ball. POIFECT. With the IR LEDs you can see very well at night. The camera's image isn't quite as good as the original but good enough to get the job done both during the day and at night.
103518||
Gus
eamarquardt
Images: 150
Re: GPS/Back Up Camera
Postby S. Heisley » Sat Mar 23, 2013 3:46 pm
That is awesome, Gus! Thanks for the write-up! :thumbsup: :applause:
Postby mikeschn » Sat Mar 23, 2013 4:35 pm
Good job Gus..
Chell's Honda comes with a backup camera in the rear view mirror. I've gotten spoiled by it...
The only thing I can think of that could make it any better is to have blind spot detectors is the side view mirrors. Do they make such a thing yet?
Postby asianflava » Sat Mar 23, 2013 4:49 pm
The factory backup camera on my truck doesn't do much for backing, it's mostly for hooking up to the trailer. It's up on the tailgate handle, if I had it on the plate, it'd get covered with snow. I had to clear the snow off this morning. I love it when I hook the trailer up by myself.
asianflava
Postby KevinR » Mon Apr 22, 2013 10:23 am
My license plate is all dented up because of all the times I've run the trailer hitch into it. This placement would either prevent that or get the camera smashed for me. I use the "crunch-pull ahead two inches" method of trailer alignment.
Nice job, I wasn't aware they made this cool dual use unit.
KevinR
Postby eamarquardt » Mon Apr 29, 2013 7:26 pm
Update: The unit failed for the fourth or so time. When you shift into reverse it powers up the camera and a transmitter. A receiver at the GPS switches the unit to the camera display mode. For some reason after a period of time, when in reverse, the display rolls from the camera view, to the menu screen, to the map display several times in the course of a second or so. It never settles down to the camera view. They are always nice on the phone and if pressed will pay for the return shipping. This time they had me send it to a facility in San Dimas, California so they could evaluate it. I offered to drive there so they could see it in action but they declined my offer.
Garmin makes a unit that is compatible with b/u cameras but they don't make a camera for it. I may investigate their offerings and see if they know of a camera that works well with their unit.
More to follow.
Gus
eamarquardt
Images: 150
