by working on it » Sun Jul 14, 2013 11:02 am
Where's the galley? (on the Simple Sleeper)... my build has too much storage and still no galley (which I regret), in basically the same size trailer. I like the A/C set-up, and the drop-down floor, but for $5k, I'd need more features.... On the drop-down, sticking down that far (and with a flat front face), wouldn't it create some wind-drag underneath (and a focus point for water and road debris to collect)? I would put a sloped shield on it for deflection.
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
