by working on it » Mon Aug 19, 2013 9:28 pm
It's hard to say what build time really is. (1) Overall design/construction time: start of concept to putting it in fully outfitted use. (2) Man-hours spent (hands on) in construction: time actually doing the physical labor. (3) This thing is taking over my life time: all of the above, with forum hours, redesigning time, correcting mistakes, boring the coworkers with stories about the build, and obsessing over it all time...all added together. In my case, (1) and (3) are actually the same thing>design start 9/15/11 to road test/weigh-in 8/17/13 (23 months). (2) 10/1/11 to 6/16/13-reconstructing the A/C ducting, reviving the battery, adjusting weight balance delayed the roadtest for 2 months after that. Compared to the builds of the talented, or of old hands at this game, my build was a comedy of errors. But, I believe I want to try my luck on another one....
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
