jandbsteardrop wrote:Hi,
We are currently getting ready to start our build but have a question about the distance between the tire and side wall of the teardrop. Currently the frame is 2" away from the tire. If we run our 3/4" plywood over the frame, along with the 1/8 luan and filon skin, then we will only have 1" between the tire and side of the teardrop. We have a 3500 axle with springs.
Question - is 1" enough or is it possible to get wheel spacers (if we have enough thread on the bolts)? Or, should we put the 3/4 plywood on the frame itself and only run the 1/8 luan and filon over the frame, saving 3/4 of a inch?
Thanks everyone...this site is fantastic!
Jack
I don't know what your clearance will become, when you have your trailer on the road, i.e: how much the flex in your suspension or tires' sidewalls will affect it. Since, I built my TTT by utilizing an unused, and undersized trailer frame I had for 18 years, and had no Idea what the trailer was capable of hauling, I used bolt on, studded spacers to solve my clearance issues, not the flat plate type spacer (which I've also used-but only when the wheel studs show thread beyond the top of the lugnuts- even on my Chevelle dragcar). Here's the process: I just had to re-engineer it (shadetree style). I started with 8" wheel on a 4 bolt hub, but quickly realized that much larger wheels, and heavier duty bearings would be needed. As I had 14" wheels on my other, larger TT, I chose 14" on 5x4.5 hubs. Went to a trailer supply house, and got a set of 5x.5 hubs and big bearings to fit the existing spindle stubs. But, after getting the 14" tires/wheels, I found that the increased section width of the 14" ST trailer tires (over the 8" tires) decreased the tire to frame clearance to about 1/4"-1/2", on the rolling chassis. I saw that once the superstructure was built, and loaded, and the trailer was being towed, that clearance would not be enough. So, I had my friend (at whose shop we were working on the trailer, at the time) source some 1" aluminum 5x4.5" to 5x4.5" spacers.
- 5x4.5 to 5x4.5.jpg (59.66 KiB) Viewed 2108 times
He had used them many times before, on various car projects he had done, and I had used similar ones on some of my VW's I had owned (in the early '70's). We both trusted them, on lighter weight vehicles specifically, so we had no qualms about using them here. I have seen them used on many street racer cars, but wouldn't trust them for off-road or high-horsepower drag cars. I don't remember the source we found, and lost my link when my computer fried last year, but here's another source of similar ones (might even be the same?)
http://www.uswheeladapters.com/shop/1-5x4-50-5x4-50-wheel-spacer/ The difference they made on my trailer is from this
with 8" tires,
(wheels, hubs, spacers added) and finally this.
Though my superstructure is inset, not hanging over the frame, I believe that spacers are a viable alternative to replacing a trailer axle (at least under most conditions). Additional info: I even used them for a year (38000miles), on my '69 Chevy pickup (6 lug wheels), hauling all sorts of loads, at all speeds. I gave them away to a guy at work who needed them, when I sold the truck. No problems there, either. Just check the torque (on both the spacer and the road wheels) whenever you can; I checked them on the truck every 5k miles, on tire rotations, and (after I learned to trust them) on my VW's every tire change (I drove 'em hard; tires only lasted me 5000 miles then). Opinions may differ; many don't like spacers of any kind.
