V-twin mini bike
V-twin mini bike
Postby noseoil » Sat Jan 29, 2022 10:20 am
Starting on a new mini bike build, so I did a crude layout to try to get a handle on the major stuff for locations. This one will use a HF v-twin motor (22 hp, 670cc), full suspension & hydraulic disc brakes. Why not?
168187
137905
noseoil
Images: 670
Re: V-twin mini bike
Postby Dan242 » Sat Jan 29, 2022 12:04 pm
Custom frame? or Bicycle?. More power/torque requires beefier frame, suspension, wheels and brakes etc. Should be lots of fun if it doesn't hurt you ;)
Dan242
Images: 25
Postby noseoil » Sat Jan 29, 2022 12:35 pm
Dan, I'm going to build it around 1" DOM steel tube for the frame, from the ground up. It's going to be my design with parts sourced from online stuff. Will add to the thread from time to time. Top speed less than 75 mph for this one.
137905
noseoil
Images: 670
Forks
Postby noseoil » Tue Feb 01, 2022 9:51 am
The front suspension arrived, still working on the layout for a lot of stuff.
168207
137905
noseoil
Images: 670
John Prine
Postby noseoil » Tue Feb 01, 2022 9:52 am
Here's a great version of "Speed of the Sound of Loneliness" by John Prine.
https://www.youtube.com/watch?v=eFvenjl ... MM&index=3
137905
noseoil
Images: 670
Allison Krause & Robert Plant
Postby noseoil » Tue Feb 01, 2022 10:03 am
137905
noseoil
Images: 670
Postby featherliteCT1 » Tue Feb 01, 2022 7:07 pm
I watched and listened to both those music videos ... very good!
featherliteCT1
Postby noseoil » Wed Feb 02, 2022 10:34 am
featherlite, glad you enjoyed the music. There's some good music out there. Here's a nice one from Long John Baldry https://www.youtube.com/watch?v=Bj_lZ4h ... rt_radio=1
The front rim was a bit too wide at the hub flanges, so I trimmed back the hubs so it will work with the narrow forks. I need to get a few more bushings for the front axle (12mm), but it's moving along slowly & progress is being made.
168221
137905
noseoil
Images: 670
Postby noseoil » Fri Feb 11, 2022 10:32 am
Front rim is in place. Made shims for the axle, checked for front brake alignment (it's off a bit), working on the caliper offset & diameter for the front disc.
168296
Due to supply chain issues, I'm getting different parts than I ordered. The rear tire arrived, it a 40 series, not a 50 which is what I ordered. It's 2" shorter in height, so I'm changing the design again...
168297
137905
noseoil
Images: 670
Postby bdosborn » Fri Feb 11, 2022 10:51 am
Wow, nice job. I'm jealous, there's no way I could do metal work like that.
Images: 806
Postby noseoil » Sat Feb 12, 2022 10:03 am
Thanks Bob, but it's easier than it looks.
Just takes a bit of thought, some time, a few $$ & being lucky to have the time & inclination to work on things. I guess I'll never get the itch scratched for building stuff, just have to keep working & making progress. I'd like to have it finished for the Run to Raton this July...
137905
noseoil
Images: 670
Postby tony.latham » Sat Feb 12, 2022 10:57 am
I'll never get the itch scratched for building stuff...
:thumbs-up:
Postby noseoil » Mon Feb 14, 2022 10:01 am
Set up the front disc & caliper. It's going to work, but there's a lot of messing around to get things right. Lots of little stuff needs to be done correctly, but it's going forward. This is a shot of things in place & rolling without any drag.
168316
1 - OK, so here's what it took to mount the brakes. The front hub flange was too wide, hub flanges were reduced in width on the mill (see above image).
2 - The axle for the rim is 12mm in diameter, but the forks are made for a 15mm axle. Bushings were made to fill in the difference & used to center the hub in the forks.
3 - The brake disc is a different design (flat, not the original "pie-shaped disc"), the new disc is a large diameter (220mm). To attach the disc, the holes were "stretched" from their centers a few hundredths to fit the holes in the hub.
4 - The hub's holes were counter-bored a bit, so the screws would sit into a small recess to allow the shoulder of the screws to sit tightly into a recess for each one.
5 - The caliper didn't match well with its original bracket, so new holes were drilled & tapped to offset it about 0.40" inboard, to match the brake disc & its location.
6 - Also due to the offset of the hub, a shim was made to slide the caliper toward the center-line of the hub a bit (1/4") to keep the pads from dragging against the disc on the fixed side.
Progress is being made, but this is a different set of tolerances than I usually have to deal with, so I'm a bit slow in figuring things out & getting them done.
137905
noseoil
Images: 670
Postby noseoil » Tue Mar 15, 2022 11:20 am
Changed a couple of details, but the front end is ready for the build now. This should be the final configuration showing the tire, rim & brake disc.
168545
Waiting for "supply chain" issues to resolve now...
137905
noseoil
Images: 670
Postby featherliteCT1 » Tue Mar 15, 2022 6:25 pm
Impressive! :thumbsup:
featherliteCT1
