I was out joy riding to Bedford, Pa and on the way home I took the Lincoln Highway and had to do a doubletake. I just had to take this.
Ira wrote:Depending on the program you're using, when you resize it, you have to have "Resample Image" checked. (If you have that as an option. AGain, it depends on your program.)
Otherwise, it will make the file's "dimensions" smaller, but it will increase the "resolution" at the same time, when it shouldn't.
This makes the image "functionally" larger for web use, because the web can't make these distinctions and the correct adjustments for you.
Web images have to be 72dpi. So a 4" wide image for the web at 72dpi is about 4" wide. The same 4" wide image at 300dpi will be 16" wide when someone sees it!!!
Yours was 19" wide! Here it is resized to 8", and I tried to lighten it for legibility.
asianflava wrote:For me, it is usually easier to resize it by pixel count, 640X480. Then I compress it by file size ~50K
