Bogo wrote: At 50 cycles a year, that is 60 years.![]()
I'll need 20 years tops. Can I return em when I no longer need em? Enquiring minds want to know.
Thanks,
Gus
eamarquardt wrote:Bogo wrote: At 50 cycles a year, that is 60 years.![]()
by 77volvo
Consumption
The Truckfridge/Indel B 50l consumes .7w when the compressor is not running, when the compressor is running on ECO my amp meter says 3.5a/44w and on MAX 5.7a/71w. Although I did not record the totals consumed, my 50l performed well, connected to 40w (labelled), actual 25w peak output measured, of solar panels and 2 - 12v 100 amp deep cycle batteries over 9 days. I set up the fridge and panels the afternoon of 8/11, and disconnected them on the morning of 8/19. Temperatures during the day were up into the 90's, but down to the lower 60's at night, and I had the thermostat set at 34. The lowest the battery voltage I observed was 12.05v, and the milk was still cold when I loaded up to head home.
TF31 SALE PRICE $399.00
Great for traveling, camping and all outdoor activities.
Portable, top opening fridge/freezer
13 ¾"W x 14 ½"H x 23"L
1.0 cu. ft.
DC 12-24 Volt / AC 115-230 Volt / 50-60 Hz
TF41 SALE PRICE $499.00
13 ¾"W x 17"H x 23"L
1.5 cu. ft.
TF51 SALE PRICEn$529.00
13 ¾"W x 20 ½"H x 23"L
2.0 cu. ft.
Bogo wrote:On depth of discharge vs. cycle life: From that Trojan battery spec. Note 80% DOD is well over 500 cycles. 50 weekend trips a year times 10 years is only 500 cycles. Chances are the battery will be killed by winter neglect, or simply die of old age before it cycle lives out for the average TD user. Note: the chart is for that Trojan battery. A typical AGM deep cycle/starting will only have 250 to 400 cycle life at 80% DOD. Still a long time for an occasional use RV.
