What type connector is this??
Anything electric, AC or DC
Postby wtcreaux » Tue Jun 30, 2015 8:18 pm
This 12-volt cord is used to power an Engel refrigerator. I am looking for one that has a 90-degree on it at the refrigerator.
133625 133626
Anyone know where I can find one?? This one sticks out too far and rubs on the shelf.
The negative terminal is flat edge, the positive has a rounded edge
wtcreaux
Images: 211
Re: What type connector is this??
Postby Dale M. » Wed Jul 01, 2015 9:48 am
Never seen "that" connector before... Possibly proprietary for manufacturer....
Dale
Dale M.
Images: 18
Postby wtcreaux » Wed Jul 01, 2015 10:06 am
Dale,
Thanks for the reply......I was coming to that conclusion after spending hours on-line looking for one. I couldn't even find a picture of one amongst the web's thousands of pics.......
wtcreaux
Images: 211
Postby halfdome, Danny » Wed Jul 01, 2015 11:41 am
Why not make a notch in the shelf to accommodate the plug.
Cost you nothing and solves the problem.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby wtcreaux » Wed Jul 01, 2015 11:53 am
Danny,
My apologies, I didn't explain well. While the refrigerator is sitting on the shelf, there is no problem. it is when I slide the refrig forward that the plug strikes a weight-bearing support. I have moved the refrig as far to the left as I can to enhance clearance but lacks about ½ "
130229 (without refrig, I will try to get one with after work)
wtcreaux
Images: 211
Postby Shadow Catcher » Wed Jul 01, 2015 4:40 pm
I see two possibilities These guys will have it if any one does http://www.alliedelec.com/search/results.aspx?term=power+cords,right+angel If they do Not have it you can modify the male end in the refrigerator to accept a more conventional cord by cutting off the guide fins. You do however need to maintain the polarity.
Postby bc toys » Wed Jul 01, 2015 7:47 pm
ITS A 12V pos on one side and neg on the other they make a 90* ones goggle 12volt connectors there should be a transformer on the plug end if it converts from 120v to 12v
bc toys
Images: 42
Postby bdosborn » Wed Jul 01, 2015 8:36 pm
Images: 806
Postby wtcreaux » Mon Jul 13, 2015 11:47 am
wtcreaux
Images: 211
Postby dales133 » Mon Jul 13, 2015 5:08 pm
I'd just contact engel, chances are one of thier models has it.
The common socket on the other end of engel is a he'll a merit socket witch is a much better connection than a standard cig
dales133
Postby wtcreaux » Sat Sep 12, 2015 12:40 pm
wtcreaux
Images: 211
Postby troubleScottie » Sat Sep 12, 2015 2:54 pm
It is a NEMA 1-15 power cord.
http://www.stayonline.com/10-amp-cords.aspx has some right angle versions.
They do not all have the round - square format. For an AC connection ( like my camera's battery charger ), this is really irrelevant. No sure about a DC connection.
Michael Krolewski
Scottish Terrier Fancier
troubleScottie
Images: 16
Return to Electrical Secrets
