what gauge wire
Anything electric, AC or DC
what gauge wire
Postby glenn201 » Sun Jan 24, 2016 9:22 am
what gauge wire do i need for my roof vent this is the one im ordering http://www.ebay.com/itm/TEARDROP-TRAILE ... mI&vxp=mtr
glenn201
Re: what gauge wire
Postby Jim.Johnson » Sun Jan 24, 2016 10:15 am
The specs indicate that it only draws 3 amps on high. #18 is good for 10 amps. I'd probably run at least #16 and nearly eliminate any voltage drop.
Jim.Johnson
Re: what gauge wire
Postby glenn201 » Sun Jan 24, 2016 7:59 pm
Jim.Johnson wrote:The specs indicate that it only draws 3 amps on high. #18 is good for 10 amps. I'd probably run at least #16 and nearly eliminate any voltage drop.
Thank you very much
glenn201
Return to Electrical Secrets
