When I was building my trailer (originally for the wife to use, solo camping, to get her out of a leaky tent), I tried to plan for all contingencies (at least where power for A/C, heating, cooking & lights, as well as having a secure, dry place to sleep were concerned). I may have gone overboard a bit (I had to write a user's manual for her to read, but she never used the trailer at all). It was mainlt about the electrical system(s). I have separate 12vdc and 120vac systems, using many fuses, master cut-offs, and circuit breakers on each.
On the 12vdc side, I have the Optima Yellowtop battery in the tongue box (shielded from other equipment and spares in the box, with ventilation), with 4 ga cables run underneath the trailer to a master cut-off switch in the galley (there's also an unattached feed from the generator in the "galley/storage area", in case I choose to use it for direct 12v, instead of 120v, and a separate circuit breaker for the trailer breakaway switch). From the master cut-off, there are 10 gauge wires run inside the cabin to a re-purposed Key storage box
on the rear bulkhead above the rear shelf, with the A/C unit next to it (master A/C switch controlling the A/C, a chassis cooling fan, and a hi-flow axial fan in the exhaust duct).
- airconditioner next to 12v control box.JPG (86.44 KiB) Viewed 1132 times
There's a secondary 50amp switch on the side of the key box, so I can turn off all 12v in the cabin, from inside. The key box has an inverter and a battery charger (both detachable, if I need them outside the trailer, and fuses for all items powered by 12v. From there, I used 14 ga extension cords (easily accessible/replaceable) to the stereo, overhead & overdoor 12v LED lights, etc.
Then there's the 120vac side. Choice of power sources: onboard 2500 watt generator or park power. The generator slides out from the galley/storage area, so it can be operated without heat anf fumes in there. I've only used it a coupla times, and only where park power was unavailable. The 120v output cable is unnattached while park power is used. When at camp, I run a 25 or 50 ft extension cord to the park power pole, then feed it thru a Taymac in-use cover into the galley (on the streetside), whre it attaches to a 6-way distribution block,
- power cord thru wall to distribution block.jpg (169.99 KiB) Viewed 1132 times
which feeds a GFCI (which supplies power to my outside lighting at camp), and to the resettable surge protector (which feeds power into the cabin, to another distribtion block).
- surge protector installed.jpg (87.56 KiB) Viewed 1132 times
I use a separate outlet on the curbside, also behind a waterproof Taymac cover, with two GFCI's and two normal outlets. I use one GFCI for my over-the-door halogen light (exposed to the weather), and the other to power my electric skillet (my easiest, preferred way to cook at camp, when not grilling).
Of course, I carry spare GFCIs, extension cords of multiple gauges, fuses, inverter, battery chargers, test equipment, tape, connectors, wiring, etc. Be prepared!
