bdosborn wrote: One thing to remember is that an inverter that is lightly loaded can be pretty inefficient. I wouldn't be surprised if the total current draw for the fluorescent lamp on the inverter isn't about the same as the 12V incandescent. P.S. Here's a link to some LED lights I made:
http://home.comcast.net/%7Ebdosborn/tea ... htBar.html
Thanks for kind comment on measuring light output. My light meter is more objective than I am, I'm trying to stay within the spirit of this forum, which is to be helpful instead of argumentative. This forum helped me a lot when I was building the Crocodile Tear, and it's payback time.
I estimated the inverter would draw 10 percent of the amperage. That could be 10 percent of the 13-watt load with one fluorescent bulb or 10 percent of its 130-watt output capability. Or 60 watts, as Bruce speculated. Opinions ar cheap. Regarding the amperage a small inverter uses -- has anybody measured it and is willing to post it here?
Bruce -- I went to your website and looked at the LED light bar you built. Nice job! From one of your night camping photos, I got the impression that it puts out less light than any of the three lights I tested. What is your impression: your LED light bar vs a bright single-bulb 12V dome light?
Not to hijack my own thread -- but Bruce, that's one beauty of a teardrop you've built! The build pix on your website show excellent craftsmanship. I liked the use of window sash locks for cupboard doors and drawers and the use of the 90-degree steel angles to attach bows. (I simply made shelves and put everything in Rubbermaid boxes. My bows fit in slots and were glued and screwed to the sides.) Your inclusion of solar panel, DVD, TV tuner, pre-amp, Direct TV dish, and speakers is impressive. (I thought a CB radio with weather band and a transistor radio were hot items!)
