Installing a 110 Electrical Port on a Little Guy
Anything electric, AC or DC
Postby NW_Subie » Tue Jun 26, 2007 11:51 am
I'm wondering how hard it would be to install a 110 electrical port on my Little Guy? :thinking:
NW_Subie
Images: 57
Postby bledsoe3 » Tue Jun 26, 2007 5:39 pm
Just drill a hole and screw and seal the port. I got mine at West Marine at Delta Park.
bledsoe3
Images: 112
Postby NW_Subie » Tue Jun 26, 2007 6:48 pm
Any issues drilling into the laminated skin? Other pitfalls?
NW_Subie
Images: 57
Drilling thru the Little Guy
Postby Pdbeta » Wed Jun 27, 2007 3:45 pm
I used a sharp (new blade) hole saw of the size I needed and a 110 volt drill. I located a suitable place on the fiberglass side and drilled the hole.
Easy clean job.
Pdbeta
Images: 21
Postby bledsoe3 » Thu Jun 28, 2007 10:28 am
I used a hole saw. Drill from one side until about 1/2 way through. Then drill the rest of the way from the other side. This will prevent a lot of splintering.
bledsoe3
Images: 112
Postby b.bodemer » Thu Jun 28, 2007 6:40 pm
Like Bledsoe mentioed....I used the same technique: drilling half way and then once it broke through witht the drill bit then finsihed the hole from the other side.
I did a test first on some scrap 1/2" oak I had and it worked great.
Barb
b.bodemer
Images: 328
Postby bledsoe3 » Thu Jun 28, 2007 9:35 pm
Subie, If you need help or don't have a hole saw, shoot me a PM.
Bring 'er over and we'll cut a hole in that sucker.
bledsoe3
Images: 112
Postby Geron » Fri Jun 29, 2007 5:22 am
bledsoe3 wrote:I used a hole saw. Drill from one side until about 1/2 way through. Then drill the rest of the way from the other side. This will prevent a lot of splintering.
I used a spade bit with the same technique. A hole saw will give you a cleaner cut but I had no problems with the spade bit. Believe mine was 1 1/4" IIRC.
g
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby Dennis T » Fri Jun 29, 2007 7:16 am
Just be careful of the hidden screws. Hit one and the bit goes bad real quick.
Dennis T
Dennis T
Images: 10
Return to Electrical Secrets
