Arne wrote:Some one had mentioned 10 ga... can't imagine anything in a t/d that would require anything heavier than 12...
If you are charging the teardrop's battery from the tow vehicle, the less resistance you have in the charge wire the more effective the charging will be.
Also, if you connect a discharged trailer battery to a running tow vehicle capable of 100 amps of alternator output at much more than 12V, a significant amount of current could flow to the trailer battery (depending on wire gauge, wire length, connector resistance, etc). As long as it has a suitably rated fuse or circuit breaker, that's managable.
